That's exactly what I ended up doing. Ended up tackling that upside down TB LoL. Honestly it's time consuming but it's doable for anyone out there that's afraid as I was. If you put your head to it you can do it, it just takes time and the right tools. I just took it apart yesterday. To get to the TB I only had to take out the fan, the turbo tube, parts of the air box and disconnect some sensors and wiring in the way. The TB was extremely bad as my gut feeling was right. Now I have everything cleaned up and have many of the wiring harnesses readdressed in new 3/8 conduit.FLXC90 wrote: ↑24 Apr 2020, 15:15 Seafoam will attack carbon build-up, but it will also attack oil sludge, which is what might be all that is sealing some crustier valve seals that Robert is alluding to. Also as stated, it isn't meant to clean MAFs and Throttle bodies, there are much lighter solvents especially for that. As far as seafoam in the fuel system as a preventive cleaner, it will not cause problems, but may not do a whole lot to help either. The answer you may not want to hear is, if you are drivability issues that indicate the TB, you 'll just have to suck it up, and pull it to clean it. Probably just more steps than anything else. Normally, the TB on these gave problems electronically, not mechanically, but if your car is circulating a lot of oil in the intake from blow-by or turbo seals then you may need it.
My delema now is whether j put it a back together today or order the PCV kit online and tackle that too since I have all this room with the TB off ? Does anyone have any tips is it really that hard I'm just not sure if I will run into any thing difficult and regret it.
