Corona bench tear down, autopsy of,a 1999 9171703 AC compressor
Has thanked: 1506 times
Been thanked: 3818 times
Musings
After removal of the clutch and magnet, 6 m8 (12 mm head) bolts hold the four pieces together
Front cap
Body half one
Body half two
Rear cap
Two reed valve assemblies live in each cap end
Bakelite pistons ride in the cylinders in each body half, they have semi spherical metal bearing on top and bottom
They are driven by the eccentric cam in the middle with axial float of the cam controlled by needle bearing, and radial by a rear bearing on the rear plate and a bushing/seal in the front plate
Needed refurb parts...110 x2 mm oring for the caps and body
Front bushing, that will be a pain to find I bet
Picture dump
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Was your goal to just tear down and see what's what? or are you rebuilding it?
Also, threads like this always amaze me in this level of photography for something like a repair forum would have been near impossible 5-8 years ago. The level of cameras in phones is just remarkable.
Has thanked: 292 times
Been thanked: 765 times
Sigh. I have so much less time for the car in these corona times. Looks good though!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
THis one was dead so I knocked it down
It looks tough to source parts although I did find the front seal at Volvo web store
9171344 $47
Someone sourced the clutch bearing orettty cheap too, will find
Has thanked: 1850 times
Been thanked: 1712 times
Why do you need 110 x 2mm 'O' rings?
Big o-rings go between each body section and the two end plates seal it up.
These things are things of beauty inside. I can’t believe be how cheap they are, looking at the precision machining.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
This type of design is often used on high pressure hydraulic pumps. It is called a swash plate design (the eccentric cam part in the middle). The hydraulic pumps are extremely close tolerances and do not tolerate any dirt. I have never seen one with front and back pistons.
How are the balls installed and removed? On hydraulic pumps, a foot with spherical bearing is held by pressure against the swash plate. They have no suction capability.
If the bushing is bronze, it should be easy to have some made. I think the O-rings could also be sourced. Someone could start a cottage industry rebuilding these. Hydraulic pumps are rebuilt for about 1/3 cost of new.
Found the reason this was a growler
The swash plate ( thanks Volvolugnut) has damage
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
I've always wanted to do this, the main deterrent was the time it would take to go down the rabbit hole to source the internal parts. The inside is every bit as beautiful as I had imagined.
