CCM/ECC not working. No control of damper motors. AC ON-button blinking Topic is solved
Has thanked: 1504 times
Been thanked: 3817 times
Re: CCM/ECC not working. No control of damper motors. AC ON-button blinking
Ugh - Jimmy has posted that sometimes they had to take the ECC out of the car and install it in another one if it got the calibration really scrambled. Maybe there is another 99 or 00 nearby
sorry.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
worst case scenario ill just lock the flaps/doors for cold during summer and hot during winter.
BMW 540i 2002
S70 Base 2000
Have you tried another ECC control module? They are pretty cheap on eBay, or put ina junkyard request
kallekula
Post by kallekula »
where is the ecc control module located?
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Well, problem might just be solved. Picked up yet another control panel / module or whatever its called and hooked it up. No blinking lights. The damper motors are just hanging by their wires now and when I turned the temp gauges and directional gauge they all turn! Thank you lord. I'm gonna install them and calibrate them without worthless vida this time to avoid any potentional mishaps. Usually I want to know what was wrong and learn from problems I solve but this time I dont give a flying fu$k as long as it works. Yay!
BMW 540i 2002
S70 Base 2000
arnebock
Year and Model: v70 2.5D 2000
Post by arnebock »
Hi kallekula,
I am having the exact same issue as you had. How do you perform the manual calibration (without VIDA).?
thanks!
Arne
On a 2000 it self calibrates. If you just replace the control unit in the dash you should have no problems
