2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
2004 S60R -- Yamaha V8 Conversion!
- Has thanked: 304 times
- Been thanked: 517 times
Re: 2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
Came across this on FB this morning, I was excited to see another B8444S swap in a P2R!
- Capture.PNG (447.6 KiB) Viewed 1560 times
- RickHaleParker
- Been thanked: 958 times
Is he doing engine and transmission?bmdubya1198 wrote: ↑29 May 2020, 09:28 Came across this on FB this morning, I was excited to see another B8444S swap in a P2R!
I'm getting there.
Yup, he’s doing an M66.
- RickHaleParker
I had a chat with him on Facebook. He is starting off with a 2006 S60R. His electrical, electronics and software should be pretty much plug and play. I told him where to find MVS and Yagger if he runs into a problem.
The B5254t4 is shot. Sometime between when I got it and how, it went to full lock up. Most likely the Antifreeze in the crankcase rusted everything in the lower end.
Yeah, that motor was junk.
- Has thanked: 927 times
- Been thanked: 1000 times
Now what? Find another V8?
Nah, he’s talking about the B5254T4. The original motor.
- RickHaleParker
The original 2.5L is now locked up, I could turn it over when I got it.
If you look above I was think of salvaging the internals in case somebody wanted them. Pistons new are $160.00 each. Connecting rods new are $200.00 each.
- RickHaleParker
Notes: In 2005 Volvo changed the High Speed CAN bus speed from 250 Kbps to 500 Kbps.
Control modules on the HS bus: ABS/BCM, DEM, ECM, ETM, SAS & TCM.
- Has thanked: 1505 times
- Been thanked: 3818 times
I’ve got one of those them there fast 2005 Busses.
