Broken vacuum line?
JLv70t5
Year and Model: 1998 v70t5
Has thanked: 11 times
Broken vacuum line?
Post by JLv70t5 »
1998 v70 t5. Replaced my boost control valve today and noticed this vacuum line was broken off I have no idea where it's supposed to go. I have an intermittent service light for EVAP. Is this related? Can anyone help me out?
Has thanked: 293 times
Been thanked: 765 times
That one connects to the TCV, to the straight nipple on the end with the two nipples. I'd wholesale review all of the vacuum lines.
EVAP code is probably one of the other, 22 year old vac lines has crumbled or has a pinhole etc. Likely unrelated.
That current open line is allowing unmetered air into the intake past the MAF, so the engine is running lean (very bad) or the ECU is compensating and it is running rich (less bad but still undesirable).
Frankly I would plan to replace all of the vacuum lines. But start with re-plumbing the TCV lines, go from there.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Take the big air hose off. You will find the other end of the small hose below and near the back of the head.
RickHaleParker wrote: 03 Jun 2020, 20:49 Take the big air hose off. You will find the other end of the small hose below and near the back of the head.
You think this goes back to the FPR? I think it's to the TCV ...
'06 S60 R, 197k
JLv70t5
Post by JLv70t5 »
If I'm not mistaken the tcv (turbo control valve) is the same a the bcs (boost control solenoid) wich is the part a just replaced. Definitely not to that. What's the fpr?
JLv70t5
Post by JLv70t5 »
erikv11 wrote: 03 Jun 2020, 20:55
I found this forum
viewtopic.php?f=1&p=276263#p276263
This is definitely it. Thanks for the help
RickHaleParker
erikv11 wrote: 03 Jun 2020, 20:55 You think this goes back to the FPR? I think it's to the TCV ...
I just took a quick look at my "98 C70 to see where the line is heading.
The other end terminates at a air pipe. Nipple at the metal pipe.
FPR it is!
'06 S60 R, 197k
