02 V70 2.4T - Screws that hold the Charge Air Pipe in place?
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 119 times
Been thanked: 15 times
Post by Jonboy74 »
Can anyone tell me what these Torx screws are and where I can get replacements? FCP Euro wasn't sure....
I'm guessing M5, but not 100% sure...it is definitely NOT an M6. I lost one a while back (it disappeared down into the recesses of the front body somewhere), and I really don''t like having this pipe not secured properly.
Thanks!
Jonboy
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I suggest going to someplace like Ace Hardware and buying several metric screws you think might fit. I do know they are different sizes for the two places. Keep in mind metric screws have about four thread pitches. The head size and type don't matter. You might even be able to return screws you don't need.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 55 times
Been thanked: 39 times
Post by EngineeringBloke »
Take one to Lowes, they have a display in the nuts and bolts section that you can thread bolts into to check the size. Don't force it or you could damage your bolt.
Has thanked: 1505 times
Been thanked: 3818 times
Well it’s Sunday morning, and I need my exercise walk to the ...
Volvo Web Parts Store
It looks like flange screw 11 or 20, depending on which charge air pipe you have
They show as M6 x16 mm hex heads on the Volvo diagram, btw
Hmmmm, mystery.
Maybe pull that other one off and take it to Lowe’s to match.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Jonboy74 wrote: 06 Jun 2020, 16:19 Can anyone tell me what these Torx screws are and where I can get replacements? FCP Euro wasn't sure....
There are lots of them screws around the car. Take one from another location to determine the thread size. Then go find a replacement at a hardware store.
Been thanked: 472 times
Post by cn90 »
I just removed the bolt and measured it for you.
It is M5 x 1.0 mm x 20 mm (length).
Either Ace hardware store or local junk yard should have it.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
That's a junkyard part for me. I try to grab a couple when I go. Easy to lose.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
You can use the Volvo web store and grab the part number, then use the fitment tab and Sometimes find a non-critical place the same fastener is used in the car, too!
