I actually never solved it, ended up selling the car with the code. Buyer didn't seem to care.
I'm pretty sure the solenoids I installed were all bad though... weird, but possible I guess. I ended up redoing all the wiring from the ECU to the solenoid and that made no difference. This car was a real mess, between incompetent "mechanics" working on it and general neglect over the years.
'01 S60 ECM-6440, New VVT Solenoid Didn't Fix
- Has thanked: 317 times
- Been thanked: 531 times
- RickHaleParker
- Been thanked: 980 times
If you encounter this again. Clean the oil galleries between the solenoid and the VVT. Like all galleries they can clog up and alter the pressure.bmdubya1198 wrote: 11 Jun 2020, 17:25 I actually never solved it, ended up selling the car with the code. Buyer didn't seem to care.
Active
Past
Past
I flushed it out with brake cleaner, but it didn't seem to make any difference.RickHaleParker wrote: 11 Jun 2020, 17:56 If you encounter this again. Clean the oil galleries between the solenoid and the VVT. Like all galleries they can clog up and alter the pressure.
- 5257 Views
Last post by LT South Africa
- 4020 Views
Last post by PixelDust
- 5386 Views
- 10 Replies
- 678 Views
Last post by lukask
- 4439 Views
Last post by jimmy57
