The new coils all had new boots. I did not detect any holes or tears on the plug boots when I swapped them around.
More and more I am thinking failed MAF.
Ran like a champ when I pulled the MAF electrical connector, but I am not getting any MAF-specific codes on VIDA.
'04 XC Engine Misfiring-Further Updated (Moisture ruled out - possible defective coils, bad MAF) Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Re: '04 XC Engine Misfiring-Further Updated (Moisture ruled out - possible defective coils, bad MAF)
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
No, I do not. Electricity and wiring aren't my strong suits either.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Replaced MAF with new purchased from FCP (none available at Harry's). Problem solved.
'95 855 auto (sold)
'95 855 auto (sold)
- RickHaleParker
- Been thanked: 958 times
Last month I cleaned the MAF electrical connector on my S40. Misfiring problem solved.
- E Showell
So, not solved. Son went to use car for work this morning. Lumpy idle back. I'm going to have to put VIDA back on the job and see if I can glean any more useful data. Bad throttle body?
Pulled two throttle bodies at Harry's yesterday, but part numbers don't correlate to what FCP says I need. Ones I pulled end in "53". FCP says I need a "54". Last one I pulled came from the same model and year and had a completely different part number (starting in "36") than the FCP part number. I did not keep the 36 since it looked really beat. Another source suggested they were all interchangeable. Thoughts on that?
And just so you don't think I am a complete idiot, the "53" throttle bodies I did pull both had original Volvo markings on them and both came from cars FCP said should have had the "54" throttle bodies per their fitment guide.
Also, I would be eternally indebted to anyone who can tell me how the throttle body wiring harness clips work. In the three throttle bodies I pulled at Harry's, I utterly destroyed the clips to get them off. Could not for the life of me loosen them for removal.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 1498 times
- Been thanked: 3810 times
The intermittent nature of this is making me think throttle body.
Headed to NY this morning, will noodle on it
VIDA will tell you about throttle action of course
- E Showell
VIDA back on it.
No misfire codes. Faulty throttle code.
Sort term fuel trim both sensor banks at zero (open loop). Long term trim both banks at 99%. Not sure what all that means as it relates to throttle, but VIDA readout said idle rpm at 200.
This looks like a throttle body problem to me.
'95 855 auto (sold)
'95 855 auto (sold)
- RickHaleParker
Spray them with WD40 and let it soak down in between the two plastic connectors. Most of the time they slide apart afterwards.
- 2823 Views
Last post by itsmekirby
- 5739 Views
Last post by chrism
