Melted coil wire covers
tombrisk
Year and Model: 2000 V70XC AWD
Has thanked: 5 times
Post by tombrisk »
Checking plugs on my 2000 V70- the protective wiring covers are mostly gone, melted, cracking and brittle.
Is that something to be concerned about?
I have some and will try to replace, but sheesh!
And puddles of them too
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
This looks fairly typical. I have replaced some and have considered doing more but the car is running well. "If it isn't broken, don't fix it" is sometimes a good strategy :-)
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
tombrisk
Post by tombrisk »
Heh. Where were you for my last shade tree 'mechanic' botch job?
Thanks~~
Has thanked: 2207 times
Been thanked: 1852 times
Perfectly normal. Plastic of this age and seeing high temps will go brittle over 20 years. I replaced all of the wire covers about 5 years ago on my 'R' and also my last V70 base. The leaking oil you have needs to be fixed as that accelerates the issue. Check for PCV pressure (glove test) and also check/replace the oil filler cap seal. Most likely brick hard and leaking.
Has thanked: 1611 times
Been thanked: 4071 times
You can buy the loom at an friendly local auto parts store like NAPA ,Advance ,Pep Boys, or Autozone.
tombrisk
Post by tombrisk »
abscate wrote: 14 Jun 2020, 08:24 You can buy the loom at an friendly local auto parts store like NAPA ,Advance ,Pep Boys, or Autozone.
Cool thanks
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Try to get wire loom with high temperature rating - at least 250 F, but 300 F is better. The cheaper, common temperature version does not last on top of the engine. IPD has the smaller sizes in the high temperature rating. The larger diameter loom is harder to find in high temperature rating. I found it at Fastenal. Use high temperature, good quality electrical tape as well (3M super 88).
