Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
Today I drove my S70 to get some groceries and I noticed when taking a left corner, some clunking noise came from the right wheel well. It sounded like a bad cv joint. I've been hassling with this axle for quite some time now. Is there an easy way of determining whether the inner or outer cv joint is busted?
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Has thanked: 1611 times
Been thanked: 4075 times
I was contemplating replacing the CV but found the right engine mount collapsing was making my right front wheel clunking noise
Thread here...watch your part numbers as there are a couple of versions
viewtopic.php?f=1&t=93660
redc70
Year and Model: 1999 c70 convertible
Has thanked: 9 times
Been thanked: 5 times
Post by redc70 »
Yesterday replaced the heater core and O rings. Going to take the bolsters off and install new air distribution damper. Getting flashing red lights on climate control module and ECM-222 code. Last week, replaced the power steering bottle and flushed the system, refilled.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I decided to replace my engine coolant temp sensor and found out it can be a pain to remove.
As my father used to say - " Give a lazy man a hard job, and he'll figure out an easy way to do it . " So one cheap sacrificial socket and a couple of minutes with a grinder.... His point was made. :)
1999 V70 GLT
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Hmmm... I have a new sensor that I want to install, might have to try this method.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Sveedy wrote: 13 Jun 2020, 13:05 As my father used to say - " Give a lazy man a hard job, and he'll figure out an easy way to do it . "
Have a buddy who was a foreman. He say lazy people are not worthless. If you want a easier way to do something, put the lazy guy on it. It might take him a week to find the least effort to do what the roll your sleeves up guy can do in two but he will find it. Then you teach the roll your sleeves up guys to do it that way. They will get the task done in one day from then on. Over all increase in productivity in the long run. Gives a whole other meaning to it takes all kinds. :lol:
Active
Past
You can also cut the wires on the sensor and then use a deep socket on the sensor; replace it with an open end to proper torque
bmdubya1198
abscate wrote: 14 Jun 2020, 08:59 You can also cut the wires on the sensor and then use a deep socket on the sensor; replace it with an open end to proper torque
In the case of removal, that would be the preferred option. If for some reason you can't get a wrench in there to tighten the new one down, the ground down socket should make easy work of it.
Sveedy
Post by Sveedy »
Personally I would have tried taking apart the plastic connector before cutting the wires, particularly with the new one. But that also didn't seem to be the right approach. Additionally there was no way to get an open end wrench in there, at least in my case. And hey, if it was a race, I'd be drinking my second beer while someone else was crimping and heat shrinking wires back together. :)
1999 V70 GLT
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
What size is the socket, might it be the same as an O2 sensor? That would make it too easy though.
Current Volvos:
