1. I have a 1-gallon ziplock bag full of relays and fuses pulled from junkyard cars. If I had to pick one relay, it would be the fuel pump relay and also instructions for bypassing it if necessary with a paperclip in the socket.
2. The only hard failure I have had is a fuel pump. That's expensive but not hard to change in a 2WD V70. HOWEVER, are you aware of the kind of fix you will be in with an AWD P80 if the fuel pump(s) goes(go) bad?
98 V70 Travel Pac
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
Just checked with Op
He has an R so he hasn’t reached Alaska yet.
- Has thanked: 987 times
- Been thanked: 1075 times
Matt kind of threw a fast ball here. I started a reply yesterday with lots of great advice until I realized I was about 8 years too late.
With the similar topics history below , we started getting a lot of these. It’s all good.
- MadeinSweden1
- Year and Model: 1998 V70 M
- Has thanked: 6 times
I agree with what has been said already. Fuel pump and having an extra Fuel Pump Relay in your glovebox would be a very wise investment. Bring the usual oils/liquids and have your battery and alternator tested. Double check inner/outer tie rod ends for structural integrity. Check axles for leaks. Check engine cam seals for integrity as well. Also bring a good spare tire, not the cheap one that comes standard. You won't regret it incase of a flat. Oh and how can we forget, make sure the timing belt doesn't need a replacement for at least 15k to err on the side of caution.
ALWAYS take the Universal Fixit Card (credit card with high approval amount). Cash stash is good too.
Zip ties. Lots of zip ties
Flat repair .....put on the outside and you have whitewalls
bronco
- Has thanked: 49 times
- Been thanked: 24 times
About 5 years ago I became an informal geocacher ! There was this family custody thing where I had to ferry a kid to see her mom every 2 weeks for 4 hours to near Worcester Mass. I would leave the kid with her and hike in some of the local hills to kill time. I stumbled on a geocache without knowing about the whole thing did a little research and got interested.PDLarson wrote: 08 May 2012, 15:29
A handheld GPS or Geocache Navigator on a smartphone for Geocaching. No matter where you are in the world, if you know how to geocache, you will always have something to do. It is a fun family friendly activity and I bet there are some fantastic caches along the way.
I never actually geocached per se , i just looked for places I thought people might put them and found 7 or 8 that way.
I also discovered this other thing called "letterboxing" , I was excited when I found that one thinking it was a geocache but couldn't figure out the inkstamp things until I did some googling.
You have inspired me to start looking for those again
- 14 Replies
- 2395 Views
Last post by E Showell
- 698 Views
- 1714 Views
Last post by doogandougie
- 2440 Views
Last post by mknoll10
- 22 Replies
- 21142 Views
Last post by Willber
