MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Georgeandkira wrote: 14 Jun 2020, 06:38
Castrol 0W-30 made my Ranger's 4.0 run silently. I've become a Castrol fan.
Are summers not hot enough to warrant the 0W-40?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
I did the follow up glove test for PCV on 2001 V70 T5 after the complete PCV cleanup and replacement. The glove sucked in at idle = complete success.
Next up: fix the tank vent system.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I pulled the crank gear, new one coming. damaged splines due to lost crank nut.
we can fix em.
Been thanked: 4071 times
Nice jones - I recall from an earlier thread the gear splines are a lot softer than the crank splines so they get damaged and the crank will be fine.
jonesg
Post by jonesg »
abscate wrote: 19 Jun 2020, 19:20 Nice jones - I recall from an earlier thread the gear splines are a lot softer than the crank splines so they get damaged and the crank will be fine.
That makes sense, sacrificial consumable part.
There is very little damage to splines, only a short section but enough to allow a wobble and condemn it.
I really need a decent 2 jaw gear puller.
Of all types of tools, pullers seem to be:
1. Expensive.
2. Limited flexibility of use.
3. Seldom used.
4. Priceless when they make the job easy.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
I recently rented / borrowed one from an O'Reilly Auto Parts. Arms were the wrong shape, fingers didn't reach far enough to grab the thing I needed to pull. Flipped the arms and fittings every which way. No go. I'd buy a good one if I thought it would do the job.
After many decades of wrestling getting a three armed puller into things, I saw someone put arubber band on the arms for the first time last week
Brilliant
Walk of shame....
BlackBart
Post by BlackBart »
I actually wondered about a huge (yuge?) hose clamp around the arms and whether it would just slip. Nothing anywhere near that big in my clamp box.
Years ago I saw a new three jaw puller design with a frame that pushed the jaws together. It looked helpful. I have not seen this design in years. Maybe they were too expensive.
