squeaky dash sound
Has thanked: 1506 times
Been thanked: 3822 times
Re: squeaky dash sound
Abby and I pulled the dash from Evita and out the tape where it belongs, on the underside. This looks completely clean from the cabin and also works totally to elinate squeaks. I used clear liquid two part epoxy by JB Weld to rebuild mounts and strengthen cracks
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 67 times
Been thanked: 9 times
Post by subzerocarfanatic »
Ok, I get the idea. I think i'm going to tackle the dash removal and put butyl tape under the dash area,seems like there aren't to many screws to remove it, so I assume like 4 screws from inside through AC vents somehow then what, 4 from engine bay side, it might be a bit of a pain but at least it will be a permanent fix I hope.
subzerocarfanatic
Does the air bag :? ,steering wheel also have to be removed to get this dash out, this might make me change my mind. Hmmm....
All th steering wheel trim, switches, air bag, steering wheel come off
Center console out
Foot kick panels off
Passenger glove box, then air bag connection
Electrical disconnects and plugs
Finally 4 m6 long bolts under hood cowl
Two people to lift out.
Plan on 3 hours first time
subzerocarfanatic
I didn't realize the entire front had to come out just to remove the dash. Guess this project won't get done after all.
When your AC stops holding charge and you know your Evap is done that is the time to take out the dash and fix all that stuff. Find a DIY and bookmark in the VRD
Toughest part...finding a relativly shallow Torx bit to release the two captive screws holding the airbag to the steering wheel. A socket type won’t work as the holes are narrow. A screwdriver type works ok. Seat them well, clamp a vice grip (tm) on it to crack them loose.
Don’t strip them ... :twisted:
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
subzerocarfanatic wrote: 21 Jun 2020, 13:04 I didn't realize the entire front had to come out just to remove the dash. Guess this project won't get done after all.
It looks worse than it is. Robert (rspi) even has youtube vids describing the procedure.
BMW 540i 2002
S70 Base 2000
