1986 volvo 240dl will not start.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
volvo240dl
Year and Model:
Post by volvo240dl »
I bought my 1986 volvo 240dl on ebay in November. The guy who sold it to me said that one day it worked and the next day it didnt. I paid 163$ for it so I say its a steal. I saw that the fuel pump was unpluged and someone may have stolen the ?fuel filter?(if so cheap bastards) from the car. Found a plate that will hold the fuel pump in place and connected the wires to it along with reconnecting the fuel line. I have my dad use the jumper cables and I try to start it. It turns over just fine actually exceptionally well for its age. Everything electronically works in the car which I was surprised. My dad asked me if you could hear fuel from the injectors pour into the engine. I couldnt answer that. Any help is appreciated.
sseir39
Year and Model:
Post by sseir39 »
When you turn the key on, does the fuel pump buzz under the car? If it does not then you may need to check the relay.
volvo240dl
Year and Model:
I checked the contacts on the fuel pump relay switch and they look really good no corrosion, but just a little cloudy. Could the fact that the connector being upside down not allow power to the fuel pump?
wojeepster
Year and Model:
Post by wojeepster »
check for spark when cranking, check for fuel at plugs, go from there.
sseir39
Year and Model:
Post by sseir39 »
Did you check if the fuel pump buzzes? In the on position but not crank you should hear a buzz under the car for a couple of seconds. This will tell you if the fuel pump is receiving power from the relay. Relay innards are the secret.
volvo240dl
Year and Model:
O ok I didnt know it buzzes with out trying to turn it on. Tried to start it yesterday. Yes I checked the connectors to the fuel pump and i cleaned them because there was a little grime on the contacts on wednesday morning. I had a friend over yesterday and had him put his hand on the fuel pump to see if he can either hear or feel buzzing noises but I got none from the 2 fuel pumps I have(got one from a junkyard). Could it be as simple as a faulty fuel pump relay? Ill take pictures if that will help you guys. I checked my spark plugs and they are pretty much brand new. Very few deposits on it.
