My 2006 V50 2.4i overheats when driven aggressively. Its a B5244S4, made in Belgium, and has a Behr oil cooler (3M51-7A095) with 4 ports. One of the top lines is coolant and the other is vacuum line.
Is it the transmission cooler? The information indicates oil coolers are found either on a diesel or turbo engine.
Could this oil cooler become blocked intermittently causing the engine to overheat?
Please advise / direct.
oil cooler on a 2.4i
crazycat
- Year and Model: 2005 xc70
- Has thanked: 17 times
- Been thanked: 6 times
That’s the transmission oil cooler. I don’t think it being clogged would cause overheat. I’d be looking at the thermostat, coolant temp sensor, or radiator/cooling fan function
- 1519 Views
Last post by fitz548
- 1319 Views
Last post by SuperHerman
