oil cooler on a 2.4i
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
WacoVolvo
Year and Model: 06 V50
Post by WacoVolvo »
My 2006 V50 2.4i overheats when driven aggressively. Its a B5244S4, made in Belgium, and has a Behr oil cooler (3M51-7A095) with 4 ports. One of the top lines is coolant and the other is vacuum line.
located on the front, left of the radiator
Is it the transmission cooler? The information indicates oil coolers are found either on a diesel or turbo engine.
Could this oil cooler become blocked intermittently causing the engine to overheat?
https://www.autoparts24.co.uk/item/D_0071_567234/
used behr UK.jpg (66.19 KiB) Viewed 1027 times
Please advise / direct.
crazycat
Year and Model: 2005 xc70
Has thanked: 17 times
Been thanked: 6 times
Post by crazycat »
That’s the transmission oil cooler. I don’t think it being clogged would cause overheat. I’d be looking at the thermostat, coolant temp sensor, or radiator/cooling fan function
