06 V70.
Teenaged son had some kind of incident with either a pothole or a curb at speed that bent one side of the front suspension (camber went from correct -0.7 degrees to incorrect +1.6 degrees - top of wheel is now farther out). There is now a visible difference between the left and right side clearances from the wheel to the strut.
So before even trying to get it aligned I'm going to have to replace suspension parts. I expect to put in a new strut, hub, and ball joint. The big question is if the knuckle got bent (part is something like $400).
Anyone have experience with this situation? Should I expect the knuckle to be bent or would the strut absorb all the force of impact?
Thanks!
Front end damage: is knuckle likely to be bent?
Junkyard price for a P2 knuckle will be under $50 and no reason not to go used on this part.
Ill bet the control arm took most of the stress and bent, too. Take a good luck at the subframe for damage, too - especially look for distortion at the control arm mounts.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, junkyards are there for this, even Ebay - it will come with the bearing and possibly with the ball joint as well. As for the question, the hub it's made out of alloy and all points that attach to other parts and very thick and reinforced. I know alloy control arms can also bend and even break, but I would doubt the hub can bend at places. However, when replacing parts I would like to turn the wheel bearing by hand to feel if it's rough at some place. Rather like you say the strut can bent, the outer and possibly the inner tie rod, the end link, the ball joint can also be weakened and must be replaced, tire&wheel need inspected. But before starting anything, I would have a careful look at the attachment points of the subframe - where the control arm is fixed. Try see if anything looks even slightly bent. Don't forget to get the good brands, a Sachs strut, perhaps Lemforder other parts - I would go with Meyle HD for the control arm.
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
This happened to my car.
Front wheel encountered curb and snapped control arm. As Abscate says, look for damage at subframe.
Below is what my damaged frame looked like followed by a good replacement frame.
Bent frame
You can see that as the control arm twisted, it caused the mount to be twisted into frame. The depression highlighted by red arrows shouldn't be there. Replacement frame
Same area but nice and flat
Bent frame
- oragex
That kinda sucks. Replace the whole subframe just from an average curb hit. Hopefully it was more solid on P2
It sucks less than having to pay a frame straightener for a Unibody, which will total the car.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Im currently in the same situation, except my shock leaked out oil not bent. My steering is wobblying, do you have any driving issues?
As i will be doing, check the upper mount to body, ive seen pics of these breaking/possible weak point. I have ordered struts from my Volvo dealership, ask them questions and get prices they were very much cheaper than online sellers. best of luck and remember "hope for the best, expect the worst"
2001 XC70 factory M58
2002 XC70 auto (parts car)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
looks like a bit above average curb hit.oragex wrote: 30 Jun 2020, 12:07 That kinda sucks. Replace the whole subframe just from an average curb hit. Hopefully it was more solid on P2
My wife uses the advanced acoustic parking method, without fancy electronics, but couldn't do that .
- amblerman
So in my case, someone other than me was driving and was distracted by map application on phone. She got too close to curb and got the front wheel essentially parallel and touching the curb. She tried to turn and that is what wedged the wheel against the curb.jonesg wrote: 01 Jul 2020, 02:32looks like a bit above average curb hit.oragex wrote: 30 Jun 2020, 12:07 That kinda sucks. Replace the whole subframe just from an average curb hit. Hopefully it was more solid on P2
The control arm bent and then snapped but not before taking out the frame. The outer CV joint ripped apart but amazingly no bearings were lost and I rebuilt the joint and it's been fine since. No body damage at all. Only thing on the body that was damaged was the mud flap. Easily replaced.
I found a donor car that also gave me new interior bits, mud flaps and a few other parts along with frame. The frame replacement was done in my driveway but took longer than I had anticipated (isn't that always the case). Car has been fine since.
- ogatrulle
- Year and Model: xc90 2008
- Been thanked: 10 times
Lots of good information here. I'll have a chance to get it up on jack stands early next week and inspect the frame near the LCA attachments to see if there is any buckling.
Caster didn't change from previous alignment so I thought maybe LCAs would be OK, but may as well replace those.
Kills me because I put all new parts there a year ago (strut, hub, LCA, ball joint). Sigh.
2006 v70 2.5T; 2008 xc90 3.2
- 11 Replies
- 1145 Views
- 1614 Views
Last post by s2zeller
- 1549 Views
Last post by harryhendo
- 10 Replies
- 2289 Views
Last post by RussB
- 45 Replies
- 2972 Views
