SC-901 3 Disc in dash CD player Topic is solved
Has thanked: 2203 times
Been thanked: 1852 times
The C70 has a much different amp to a sedan/wagon. I don't know if it has a separate Dolby unit or if it is integrated. I am assuming you have a center speaker on the dash? There was a thread recently on problems with a 'regular amp' that someone had just fitted. It was dirty/bad connections that were the issue on the cables. As you know the amp is in the trunk on LHS behind a panel. Check it's connectors too.
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Separate dolby unit on the C70, plugs into the back off the SC-901 like on the V/S70.
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
scot850 wrote: 02 Jul 2020, 06:20 I don't know if it has a separate Dolby unit or if it is integrated.
The separate Dolby Pro Logic unit is Volvo part number 3533799.
1998 - 2004 C70 Convertible
1998 - 2002 C70 Coupe
1998 - 2000 S/V/XC 70
Active
Past
Thanks for the education Rick! Much appreciated.
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 75 times
Been thanked: 10 times
Post by subzerocarfanatic »
scot850 wrote: 02 Jul 2020, 06:20 The C70 has a much different amp to a sedan/wagon. I don't know if it has a separate Dolby unit or if it is integrated. I am assuming you have a center speaker on the dash? There was a thread recently on problems with a 'regular amp' that someone had just fitted. It was dirty/bad connections that were the issue on the cables. As you know the amp is in the trunk on LHS behind a panel. Check it's connectors too.
Yeah, i had the amp out a few months ago when detailing the trunk area and installing new bulbs and tail light housing and I cleaned all the connections before installing it back but i will trace the pro-logic wire to find it and clean all connectors.I assume electronic cleaner or isopropyl is sufficient.
Contact cleaner is best as it does not leave a filmy residue like IPA does.
Been thanked: 4068 times
Volvo’s are judgy. They won’t play any music by a Madonna, the BeeGees, or Supertramp.
Classical will always work, as well as anything by Prince.
Bach organ music in the S70, awesome
subzerocarfanatic
abscate wrote: 03 Jul 2020, 04:17 Volvo’s are judgy. They won’t play any music by a Madonna, the BeeGees, or Supertramp.
I can't wait to hear the full stage sound of the Pro-Logic when it is working properly,I was blown away by how good this system sounds,best factory stereo I have ever heard!
My favorite attorney in NJ blessed me with that system in Abbys S70 when I bought her
