850 Tachymeter Instrument Cluster replacement
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Hy buddies !
New question :
My car is from February the 28, 1995. On my tachymeter instrument cluster, I have only the regular watch. Which is already cool !
Tachymeter instrument cluster minus.jpg (55.13 KiB) Viewed 787 times
As a normal human, I'm never satisfied, I would like the install the "full package" (clock, watch, next airport for feed kerosene, which CD is playing on my SC 901, where's my wife and kids), and so and so.
Tachymeter instrument cluster full.jpg (63.87 KiB) Viewed 787 times
Is it possible, I mean, is my car - pre-equiped ? Any idea.
Tanks to the ones that will answer, if answer there is;
Manov
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
good question. I'd guess it would work, maybe you don't have the exterior temperature function of the better cluster (if your car came w/o a temp sensor).
The turbo gauge won't work if you have a NA car, that's for sure.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
There is a rumour that board computer needs to be activated at dealer for cars which are not equipped with it originally.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1851 times
Been thanked: 1712 times
Can't recall on the 850 how the LCD is controlled. It may be via a switch below the cluster like the S/V70.
It is worth checking behind the blank switch covers. In the V/S 70's for example some were not fitted with the Tracs OFF button. But if you have a button you can pull the blank cover and fit the switch. Maybe your car is the same and is already pre-wired.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
You mean the trip computer? The car *should* be pre-wired for it. I know on 2 of our cars that came without it, the plug for the panel switch was behind one of the blank spots on the dash.
There should also be a connection on the back of the instrument cluster (at least there is on the VDO ones) (The small one on the back of this picture)
manovlov
Post by manovlov »
Thanks to all of You guys, you're amazing !
I have to unscrew the dashboard anyway to replace it. I will make a picture an the test at this time.
Thanks again to all of you.
Manov
Chuck W
Post by Chuck W »
I *think* the connector for it should be yellow or green. (Whatever the color of the back of the dash switch is)
manovlov
Post by manovlov »
I will have to open the cluster to replace the clock module...
