ZionXIX wrote: ↑23 Jul 2020, 13:12thank you. i will keep that in mind.CIK7 wrote: ↑23 Jul 2020, 12:15There are 2 lines running underneath the coolant reservoir to the firewall. The smaller line is actually 2 lines bolted together. The orifice is in that smaller line. You have to remove the line completely before opening. I did it the hard way. I recommend unbolting the pieces behind the headlight before disconnecting at the firewall. It will give you more flexibility. Pay attention to the direction of the orifice when replacing.bmdubya1198 wrote: ↑22 Jul 2020, 11:49 Ugh those quick disconnects SUCK. Such a pain to release. I bet that orifice tube is nasty, mine was caked up with so much garbage. I guarantee someone used stop leak to try to fix the evaporator leak, but of course it won't work since it couldn't get past the orifice tube.
- CIK7
- Has thanked: 328 times
- Been thanked: 87 times
- Has thanked: 1506 times
- Been thanked: 3818 times
The orfice tube is the heart of the system it controls the expansion of the high pressure coolant to low pressure, generating the cooling power
I put ina custom passenger foot vent for those smelly soccer feet
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
The Nabber 99 is mine so it's not as bad as it looks!
07 V50 T5 AWD M66 ~146k miles
- Has thanked: 927 times
- Been thanked: 1001 times
What looks bad?
- 2000c70hpt
- Year and Model: 2000 C70
- Been thanked: 8 times
Yeah I bought the tool about a month before I decided to start the job. Replaced all cam seals whether they needed it or not, changed the front crank seal as it was leaking, and only got an ets light when done. Probably due to pulling the main relay to turn it over. Yes I turned it by hand first. Changed the serpentine belt tensioner pulley and replace the upper torque mount on the engine. No more oil leaks from the engin. Now to figure out the transmission leaks. I think it’s the case seam but I’m hoping it’s just axle seals, and a pan gasket.
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
- smacknab
Prepped for and started the engine removal to do the clutch/flywheel/release bearing. Stopped as I was losing light and I couldn't disconnect my clutch line from my release bearing assembly. I'm leaving it to soak in PB blaster overnight, but how bad does this look? My thought is that the line doesnt have nearly as much pressure as a brake line so I could get away with not replacing it. Any thoughts?
When the rust perforates the line, you will have no clutch. You good with that?
Man Beetle hiding in garage
- Has thanked: 304 times
- Been thanked: 517 times
Yeah, it would probably be a good idea to order a new line.
