MY Mechanic was reaching up in there and said it was an o-ring.
Motor works fine.
I guess he is referring to the piece between the tank bottom port (connecting) and the tubing?
Does anyone know if this is a part available to buy separately?
Windshield Wiper Fluid Tank Leak
plumsmooth
- Year and Model: V70 Wagon 2004
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
This just came up.
Go here: viewtopic.php?f=9&t=94652
In my case, the thimble-sized sieve/grommet would've been better installed with a slight smear of sealant before shoving back into the reservoir.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
All local parts house has a box of O-Rings (similar to below) for you to choose from so shouldn't be a problem. Use a little silicone grease when installing so as not to pinch or shear it. Petroleum lubricates will swell the O-Ring unless it's synthetic.plumsmooth wrote: 01 Aug 2020, 12:38 MY Mechanic was reaching up in there and said it was an o-ring.
Motor works fine.
https://www.ebay.com/itm/SAE-225pc-Rubb ... SwnY1dl-fJ
plumsmooth
Is it possible it is one of these?
The problem is he said he didn't (and I couldn't) see it. He opened up the wheel well (not the bumper) just enough to reach in there and push it around while the water rained on his head! I said sorry I didn't bring an umbrella.
- 4G0D1VSG.jpg (2.4 KiB) Viewed 634 times
- 0P9CC5GH.jpg (2.35 KiB) Viewed 634 times
Georgeandkira
Mine looked like the top one.
