Does someone have Tuned .Bin file S70 T5?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2657 times
Been thanked: 1248 times
Re: Does someone have Tuned .Bin file S70 T5?
Post by matthew1 »
manovlov wants to know about these ECU files... do they add HP, what else are they for, etc.
manovlov, I know a little... they can be used after a manual swap to enable things that the car needs to make it run with a manual, or if the owner installs a larger turbocharger.
Also -> Amazon link
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
Ah. The M4.4 Wiki link covers the conversion of an M4.3 car to an M4.4 ECU, but also the main purpose is for being able to adjust settings and parameters and flash a new tune file to the ECU. The focus is on the M4.4 units.
The Bosch M4.4 code has been cracked pretty well, and the -607/-608 files listed are also set up to allow for data-logging, etc to be able to fully tune a car after making changes. Either something as minor as from an auto to a manual, to as major as a fully built engine with different turbo, injectors, MAF, etc.
I personally have used that info to convert both of our cars to the flashable M4.4 ECUs. I've used it more for adjusting to non-stock components (Different injectors, turbos, etc) and not as much for highly detailed tuning, but the capability is there.
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
The M4.4 ECUs are pretty easy to write in boot mode. As I know, it is write only mode. Does anybody know, is there a way to read flash content through K-line? I don't like to solder out and back flash chip every time I need to save original file.
If my English is bad, please correct me :oops:
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
matthew1 wrote: 07 Aug 2020, 15:35 manovlov wants to know about these ECU files... do they add HP, what else are they for, etc.
Merci Matt,
I do understand better to what that is used for.
Manov
Chuck W
Post by Chuck W »
Azik09 wrote: 08 Aug 2020, 00:16 The M4.4 ECUs are pretty easy to write in boot mode. As I know, it is write only mode. Does anybody know, is there a way to read flash content through K-line? I don't like to solder out and back flash chip every time I need to save original file.
There is no way (currently) to read what is on the flash.
I would keep your original ECU and have a spare for tuning/flashing. This is what I do.
You'll always have the copy of the previous tune file saved, so you can always reflash that if you have an issue.
