Has thanked: 1504 times
Been thanked: 3817 times
:D
It has never run for me, no.
:D
Compression, timing, shark all good
Time to turn to fuel delivery ...what parts to throw at it? :roll:
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Fuel pressure? Injectors? Fuel pump, pressure regulator, fuel filter
Fuel pressure at rail first, then injector volume/pattern
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Didn't your mother teach you not to throw parts (or your shop teacher!)
Current Volvos:
On the edge of starting a thread for this crank, no-start.
!998 V70 NA
New reworked cylinder head - planing, valve lapping, valve guide seals
Compression test ok cold, wet at 150-180 psi
Have good spark at Number one plug
New cap and rotor
Supply voltage at fuel injectors in 12.4V with battery at 12.5V
Fuel pressure 38 psi at key on, 42 psi during cranking
Fuel pressure holds for 30 minutes
Engine timing confirmed correct, non VVT engine of course.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
CPS?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Did the PCV upgrade and it helped with the pressure.
I used ZionXlX's internal spring idea, but incorporated a EMT sweep for the 90*
3ft of the oil resistant 5/8" hose ( from a heavy equipment parts store )
4ft of the same in 1/4"
A relatively light compression spring
1/2" EMT sweep
$ 20 and change.
1999 V70 GLT
Don’t forget to remove the bracket from that starter in the right side
Volvo discontinued that and no longer replaces it
The two m10s and the pins hold the starter in fine.
abscate wrote: 10 Aug 2020, 10:04 On the edge of starting a thread for this crank, no-start.
!998 V70 NA
New cap and rotor
Spark plugs new
Today’s chapter. Noticed engine relay was not pulling in. Swapped with air pump them spare.
Relay now pulls in
Still no start.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
!998 V70 NA
New cap and rotor
Have you checked for injector pulse?
