98 V70- What should I do while the engine is out of the car ?
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Re: 98 V70- What should I do while the engine is out of the car ?
Post by Goupil »
Thanks for all the answers
I'm adding heater/coolant hoses, front crank seal and cam seals to the list. I'll inspect the power steering and replace if needed, as those are quite pricey.
I will most likely pull the engine up and out, I don't have enough room in my garage to drop the subframe :x
Once I get my shopping list done I'll put it here, if anyone plans on doing the same job.
Quick question while I'm at it: do an 850R and a 2.5 LPT V70 like mine have identical clutches ? Mine has been converted to single mass flywheel with parts from an 850R according to the seller
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
With a task list this long, I hope you have alternate transportation during this project.
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Just did this to do my clutch and flywheel a couple weeks ago. If you're replacing the AC compressor you should replace the accumulator/drier/receiver and since you'll have the system open you could pull your lines and flush them with a solvent (I rented a free kit from O'Riley's). While you're doing that you could put in a new expansion valve as well.
If you have an internal slave cylinder you could replace that as well. I also replaced my rear main seal, transmission input shaft seal, and both axle seals. Make sure to drain your transmission oil first, and have replacement fluid. If it were me I'd try to clean the drain first and catch the fluid in a clean container since the transmission takes 2.1 liters and it's annoying to buy 3 liters for that. FCP has a better price on Volvo manual transmission oil than the dealer.
07 V50 T5 AWD M66 ~146k miles
Has thanked: 1507 times
Been thanked: 3823 times
Valvoline synthetic transmission gear oil is fine in these. Running it in both of mine
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
The R clutch disc and cover are different from the base version. IIRC different diameter, definitely more grip
Current Volvos:
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 36 times
Post by theWIFES_S70 »
How could I forget...
SUBFRAME BUSHINGS!!!
viewtopic.php?f=1&t=77040
:mrgreen:
Retired:
2015 Volvo S60, T5, 85K
volvolugnut wrote: 10 Aug 2020, 15:19 With a task list this long, I hope you have alternate transportation during this project.
He’s in France. They do transportation really well over there.
I did a five year gig in Paris, and once I got a bunch of frantic from phone calls from my colleagues on Sunday night.
“We must warn you there is action planned in the RER B line ( the one I take to CDG airport)
The schedule will he delayed, and trains will come only every 20 minutes.”
:lol:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 10 Aug 2020, 18:49
:lol:
:lol: must be hard waiting for public transit over there!
theWIFES_S70 wrote: 10 Aug 2020, 18:44 How could I forget...
:mrgreen:
YES... definitely a great idea to replace those.
Goupil wrote: 10 Aug 2020, 13:37 Thanks for all the answers
Yes, you can use the 850R clutch with your car. I have one in my car and it's been great.
Goupil
Post by Goupil »
I bought a 940 and a road bike last spring to be able to tackle bigger jobs on the V70 :mrgreen:
:mrgreen:
I replaced those a few weeks ago, but yeah would have been easier to do with the engine out, I was just bored and ready to suffer :lol:
smacknab wrote: 10 Aug 2020, 16:19 Just did this to do my clutch and flywheel a couple weeks ago. If you're replacing the AC compressor you should replace the accumulator/drier/receiver and since you'll have the system open you could pull your lines and flush them with a solvent (I rented a free kit from O'Riley's). While you're doing that you could put in a new expansion valve as well.
My AC system has been open for an unknown amount of the time, there's a lot to replace :roll:
Mine is external slave cylinder but the threaded rod on it looks bent :? Doesn't look too expensive, might swap in a new one in
Transmission seals sounds like a good idea. Just remembered that I couldn't get the drain plug loose with the gearbox in the car (ended up using a syringe through the filler), another thing added to the list :mrgreen:
Those ac parts are cheap, about 20 EUro, other than the compressor. Rein brand is fine
