2001/1998 parts compatibility
Jahskew22
Year and Model: 1998 v70xc
Has thanked: 2 times
Post by Jahskew22 »
I have a 1998 v70xc that needs a new motor and i found a 2001 v70xc i hope to use as a donor car. Can i put a 2001 motor and trans in a 1998 platform?
Thanks in advance! First post:)
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Engine...not without modifications...cap & rotor vs.coil packs,etm...etc.
Transmission... if it's auto....NO.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
So, next step, what is the problem with the original motor, Hole in the block or a burned piston? Or maybe something less drastic that might be fixable...We're here for you.
Current Volvos:
Has thanked: 1848 times
Been thanked: 1710 times
Someone I used to know fitted a 2005 FWD V70 motor into a 98 AWD with stick shift. Like misha says, issue is change of tech. I believe in my friends case he 'down-graded' the engine to a 98 motor by removing the VVC and fitting the earlier car parts.
