Best Timing Belt Service DIY Info
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Some people say the serp belt is easy, I find it pretty tricky when it keeps jumping off one of the lower pulleys :(
What the videos usually don't show is how to slip the belt on without removing the crank pulley, how to adjust the later type of tensioner (mid 2004-up) and also how to release the cam hubs tension.
Has thanked: 1611 times
Been thanked: 4072 times
I think it’s possible to do the 1999 timing belt without removing the crank pulley but I wouldn’t. The contortion is likely to damage the timing belt . The 1998 and earlier are easier.
I have the nice AKN tool for SERP belt but never realized the trick of using that tool with a 14 mm box/open for the P2 SERP belt, so today I am wiser man. Thanks Jason and FCP.
Been thanked: 504 times
Post by cn90 »
Serp belt is difficult with 1 person.
A trick is using bungee cord with hooks to apply tension on the belt while you try to route it through the pulleys.
justanotherhumanoid
Year and Model: 2006 S60
Has thanked: 7 times
Been thanked: 17 times
Post by justanotherhumanoid »
I just did this while replacing my water pump. I did it without a second set of hands but it would have been much easier with another person. Best purchase I made beforehand was the serpentine belt tool from ipd. Also, second what abscate says, don't try to bend and twist the timing belt to get it past the crank pulley, you can damage the belt fibers and it's just not worth the risk to your engine versus the time you might save. You might also consider a crank-locking tool which will make it much easier to remove and reinstall that pulley.
Other handy items to do while you're in there: idlers/tensioners should be changed with the belt, it's easy to remove the PS pump and change the thermostat/housing while you've got the serp belt off, and of course the water pump (which I've heard is probably good for well over 100, like 150k or maybe up to 200, but they're not very expensive either).
Here are some links I found useful:
Water Pump & Timing Belt: https://blog.fcpeuro.com/replacing-the- ... lvo-s60-t5
DIY: 2005 Volvo XC90 2.5T Timing Belt, Water Pump, Serpentine Belt: viewtopic.php?f=10&t=83521
Serp Belt and Tensioner Replacement: https://blog.fcpeuro.com/volvo-s60-serp ... eplacement
2006 S60 2.5T AWD - Build Log
do88 intercooler, all aluminum radiator, XC90 aux transmission cooler, magnefine ATF filter, Snabb intake elbow & throttle body pipes, custom oval exhaust, rebuilt 16T swap, 17x8" team dynamics pro race 1.2 wheels, ipd sway bars, R brake swap, Hilton tune, sunroof shade that slides open when I step on the gas and closes when I stand on the brakes.
Good for at least 250k.
Interesting that on early p80s it gets changed at 2nd timing belt at 140k, but in the 1999-2000 it goes to 210k, for the same part
The one you want is 80-100 USD, Aisin , with or without the Volvo logo
