Check Engine Light With Not Working Temperature Gauge
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Hello folks, hope you all are managing the mask era good enough!
Out of the blue, my check engine light came on, with no message in the message window. Looking around on the gauges, I realized the temperature gauge is not working; the pin is way down to the left. What might this be?
Thanks.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
Has thanked: 1611 times
Been thanked: 4075 times
Could be as simple as a failed engine coolant temperature sensor (ECT)
That would probably also generate an engine error code and your light
Oka
Post by Oka »
abscate wrote: 08 Sep 2020, 04:50 Could be as simple as a failed engine coolant temperature sensor (ECT)
The temperature sensor fail is what I was suspecting also. The other thing would be the thermostat, but this I think, if it fails, would give a wrong temperature on the gauge.
By the way, this morning, I drove it from one spot to another, just about 30 feet drive and the auxiliary fan came on.
Thanks for your reply.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
i wouldnt worry about the fan working, there is no way the car can overheat after 30 feet, i know AK can get hot.I would check the easiest thing first is the sensor on the engine housing then you may need to take the DIM apart.
2001 XC70 factory M58
2002 XC70 auto (parts car)
Oka
Post by Oka »
darrylrobert wrote: 10 Sep 2020, 06:01 i wouldnt worry about the fan working, there is no way the car can overheat after 30 feet, i know AK can get hot.I would check the easiest thing first is the sensor on the engine housing then you may need to take the DIM apart.
How can I check the Engine Temperature Sensor, except to replace it?
I had replaced the "Water Temperature Sender" back in September 2019.
Thanks.
Oka
Post by Oka »
Oka wrote: 10 Sep 2020, 11:05
Thanks.
Just found how to test the sensor. Will do the tests and report.
