The second one sounds like a more important reunion! That's awesome.
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
07 V50 T5 AWD M66 ~146k miles
- Has thanked: 304 times
- Been thanked: 517 times
Wow... that person really likes cats!
- Has thanked: 1505 times
- Been thanked: 3818 times
Rollled up the Taconic at 55 in Cruise last night bringing home my daughter from JFK
It was lovely hearing ME7 demand torque and spool the turbo on the hills. Stayed in 5th the whole time except for a couple of hills where it ran away
This morning.
Oil change and fixed exhaust leak
This morning.
- Has thanked: 2655 times
- Been thanked: 1248 times
bmdubya1198 wrote: ↑08 Sep 2020, 20:573 ton is a little overkill for the compressor housing, but it works.
Nice!abscate wrote: ↑11 Sep 2020, 10:25 Rollled up the Taconic at 55 in Cruise last night bringing home my daughter from JFK
This morning.
What's RPMs in 5th at common highway speeds? My Alltrack runs at 3k @95MPH in 6th, which is the ratio I'd have chosen as an engineer. In other words, normal hw cruising is under 3k for good MPG.
The turbo is back in the car with a new CHRA... and the problems persist. Still have that annoying whine and the boost still acts weird. I'm down to a clogged cat on the boost issue... I have NO idea what else it could be. It boosts to around 12 PSI, backs off to 10, then eventually builds back up to 15 PSI where it should be. Really weird.
Anyway, the Japanifold added a nice sound to it in the high revs, so that's nice! Definitely worth the upgrade while I was in there, especially considering the flow increase.
On a positive note, if anyone needs a new turbo, turborebuild.co.uk was a great choice! $185 for a brand new VSR balanced 19t CHRA with 2 day shipping from the UK. Not bad! It even came with all the washers and the drain gasket. They also offer upgrades and upgrade parts. I was considering a billet compressor wheel, but I decided to hold off since I'm still planning on going with a K24 eventually.
Sounds like a collapsing hose or old/torn/leaking CBV.bmdubya1198 wrote: ↑12 Sep 2020, 08:32 The turbo is back in the car with a new CHRA... and the problems persist. Still have that annoying whine and the boost still acts weird. I'm down to a clogged cat on the boost issue... I have NO idea what else it could be. It boosts to around 12 PSI, backs off to 10, then eventually builds back up to 15 PSI where it should be. Really weird.
I've got a Japanifold hanging on the wall in my garage. Hint to myself.
My last picture shows 2200 rpm at 46 mph, I must have been in 4th for the picturematthew1 wrote: ↑12 Sep 2020, 08:18Nice!abscate wrote: ↑11 Sep 2020, 10:25 Rollled up the Taconic at 55 in Cruise last night bringing home my daughter from JFK
This morning.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
Happen to replace the turbo control valve? My guess is the pressure may be getting high enough to push through it. If it isn't the CBV or a hose, my guess would be this... (Assuming the ECU isn't causing the issue intentionally)bmdubya1198 wrote: ↑12 Sep 2020, 08:32 The turbo is back in the car with a new CHRA... and the problems persist. Still have that annoying whine and the boost still acts weird. I'm down to a clogged cat on the boost issue... I have NO idea what else it could be. It boosts to around 12 PSI, backs off to 10, then eventually builds back up to 15 PSI where it should be. Really weird.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
Picked up towing hook, rear abs sensors, the fuel pump and new front engine mounts from the V70 waiting for installation on the 850. I have still 2 weekends to finish the job (including this f*%£àç§"ing slave cylinder, of course), and then back to university again till June to get my "graduation". At 56 y.o it should be time !
