Not the first time this has happened.
The first time the mechanic repaired the top plates. A couple years later a different mechanic said it was a loose abs.
Common for the abs to come loose and rattle a bit?
Car has around 160k miles but we get a lot of potholes around here
Clunking sound front wheels
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
So is it a, "clunk", or does it, "rattle a bit"?
Test each drop link by exposing them by turning the steering wheel fully in one direction and grab it. If you get any movement, replace 'em. 160K is well beyond their service life.
You can see a dead strut (won't extend one bit) and a worn sway bar link aka drop link.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Worn sway bar links can be diagnosed
by disconnecting the lower end and wiring the link back out of harms way. Then drive the car and see if it still clunks. It it does still clunk then You may have a worn out spring seat.
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Been thanked: 5 times
The sway bar end links are suspect. The good news is that they are cheap and easy to replace. Lemforder is a good brand.
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Good advice above ^^^ I vote sway bar drop links.
For loose abs, do some crunches and sit-ups. Just start with 10 or 15 a day and see how you feel.
Good material, well struck.BlackBart wrote: 15 Sep 2020, 14:20 Good advice above ^^^ I vote sway bar drop links.
reverend
- Year and Model: 2006 V70 2.5t
- Has thanked: 2 times
- Been thanked: 3 times
You can USUALLY tell the sway bar links by grabbing them and yank/push/pull on it like a madman (grab it, then shake it like you're throttling your best friend after you found out he slept with your girlfriend).
If it rattles/clunks, it needs replacement. If it's solid, it's LIKELY not it.
It can be the top spring seat. The little bushing in it separates from the rubber and allows too much movement.
I had a clunk but when I push and pulled on the links they were silent, any suggestions?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Speaking of these end links.. I think it's a little trickier to test them. I tested mines, pulled with force - no play. Removed the nut, turned the small bj by hand, no play. Put back, tightened down with force, still noisy. I'm getting the feeling these will knock if the small bj is no longer super tight to rotate - when the end link is new, the bj is very stiff to move by hand, as they get old, it becomes easier to move even if it has no play. Just a theory. Also, I have the feeling the anti roll bar may move sideways and may also kick on the control arm on cars with over 150k miles
- 10 Replies
- 5669 Views
Last post by JimBee
- 1777 Views
Last post by jbkeene
- 838 Views
Last post by azureblue
- 972 Views
Last post by Cees Klumper
- 13 Replies
- 3209 Views
Last post by Clockboy
