Clunking sound front wheels
qwertyjjj
Year and Model: V70 2004
Post by qwertyjjj »
Not the first time this has happened.
The first time the mechanic repaired the top plates. A couple years later a different mechanic said it was a loose abs.
Common for the abs to come loose and rattle a bit?
Car has around 160k miles but we get a lot of potholes around here
Georgeandkira
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
So is it a, "clunk", or does it, "rattle a bit"?
Test each drop link by exposing them by turning the steering wheel fully in one direction and grab it. If you get any movement, replace 'em. 160K is well beyond their service life.
You can see a dead strut (won't extend one bit) and a worn sway bar link aka drop link.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Worn sway bar links can be diagnosed
by disconnecting the lower end and wiring the link back out of harms way. Then drive the car and see if it still clunks. It it does still clunk then You may have a worn out spring seat.
qwertyjjj
Post by qwertyjjj »
Well it's a constant rattling whilst driving particularly over bumps. On a flat road there is no sound. Front left and front right
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Been thanked: 5 times
Post by Herb Goltz »
The sway bar end links are suspect. The good news is that they are cheap and easy to replace. Lemforder is a good brand.
2012 s60 t5
2006 XC70
2004 XC70
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Good advice above ^^^ I vote sway bar drop links.
For loose abs, do some crunches and sit-ups. Just start with 10 or 15 a day and see how you feel.
Been thanked: 4065 times
BlackBart wrote: 15 Sep 2020, 14:20 Good advice above ^^^ I vote sway bar drop links.
Good material, well struck.
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 2 times
Been thanked: 3 times
Post by reverend »
You can USUALLY tell the sway bar links by grabbing them and yank/push/pull on it like a madman (grab it, then shake it like you're throttling your best friend after you found out he slept with your girlfriend).
If it rattles/clunks, it needs replacement. If it's solid, it's LIKELY not it.
It can be the top spring seat. The little bushing in it separates from the rubber and allows too much movement.
I had a clunk but when I push and pulled on the links they were silent, any suggestions?
:lol:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Speaking of these end links.. I think it's a little trickier to test them. I tested mines, pulled with force - no play. Removed the nut, turned the small bj by hand, no play. Put back, tightened down with force, still noisy. I'm getting the feeling these will knock if the small bj is no longer super tight to rotate - when the end link is new, the bj is very stiff to move by hand, as they get old, it becomes easier to move even if it has no play. Just a theory. Also, I have the feeling the anti roll bar may move sideways and may also kick on the control arm on cars with over 150k miles
