NA intake runners vs turbo
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I came across a '94 na 850 in the wreckers yard the other day. I've been thinking of doing the na intake/throttle body etc mod but this intake had some sort of linkage system between #3 and #4 runners so I left it. My question is; is there a difference in the size etc of the intake runners between the two intakes ? Or is it strictly a difference in bore openings where the throttle bolts on ?
1999 V70 GLT
1999 V70 GLT
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
IIRC the plenum and runners are the same. The t/b inlet is choked down, maybe for off-boost velocity? I've seen where people have bored the turbo manifold entry. Also, the 93 and some 94 manifolds were double ported with variable volume intake system (VVIS)that would be the linkage you saw, two sets of runners in one, operated based on RPM and Load.
If you're in to it, that motor has the preferred cams for swap into the T-5 motor!
Current Volvos:
- Sveedy
Well then maybe I'll grab them. Question - What is the usable lifespan of the cams ? The car at the wreckers has 160K on it. Looks like catastrophic engine failure due to timing belt breakage.
1999 V70 GLT
1999 V70 GLT
That Variable intake manifold has got to be hard to find and I’m guessing NLA from Volvo. Grab the whole thing!
- Has thanked: 311 times
- Been thanked: 817 times
But who wants VVIS??? No P80 manifolds are still available from Volvo are they?
Get a 95+ intake manifold, straightforward.
- callahanoffroad
- Year and Model: 1995 850
- Been thanked: 53 times
I have a variable intake manifold it's great when the thing actually works. Otherwise it's got no get up and go in the bottom end
- Sveedy
If the only difference between the two manifolds is the throat opening, then I'll bore out the opening on my turbo manifold. That way I don't have to spend $50 buying a different ( na) one. And I believe I'd still need to drill/tap that one for vacuum lines anyway.
1999 V70 GLT
1999 V70 GLT
Yes, one solution is to bore out the turbo manifold.
I don’t have time to sit next to my manifold all night reading “Great Expectations”
- Sveedy
Guess I'm a fast reader
With the way I'm planing on doing it, I should be done in a bit over an hour. Most of that time will be spent in set up.
1999 V70 GLT
1999 V70 GLT
- 2038 Views
Last post by sergitin32
- 527 Views
Last post by erikv11
- 7359 Views
Last post by rspi
- 17 Replies
- 6061 Views
Last post by biohazrd76
- 745 Views
Last post by Vazfx16
