Hello everyone.
I've been working on a friend's S40 and I can't for the life of me figure out what the issue is here. The car runs absolutely fine, but I can't get these codes to go away for her to pass emissions. It's got a new MAF on it. I just have to think this many ECM codes (to no ill effect somehow) have to be tied together somehow.
2007 S40 Various ECM codes but car runs great
- RickHaleParker
- Been thanked: 977 times
Pull the ECM and clean the connectors.
Active
Past
Past
I actually did that yesterday. After being unplugged from the battery for an hour or two after cleaning the check engine light was off. Came back today according to my friend.
- RickHaleParker
You did clear the codes. They do not clear on their own.
Clean the connectors on the sensors and check the wiring.
MAF:
Short-circuit to ground in the signal cable or Open-circuit in the signal cable .
FTS:
Short-circuit to supply voltage in the signal cable or Damaged fuel temperature sensor.
MAF:
FTS:
Active
Past
Past
