Serpentine belt tensioner
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Mines wobbling back and forth,could this be the pulley or tensioner or both. I know the 12 mm bolts to remove it. How do I put the new one on?. Is there any torque or anything I need to know about. It's all one piece. 94 Volvo 850.
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
hi i done mine recently its easier than it looks esp if you have smallish hands,in the middle of the tensioner you see a square hole you need a tool i diyed mine out of a bit of scrap square wheelchair frame and you then lock on a spanner and turn it till all the tension is off the belt and then you see a hole in which to insert a splitpin or similar in order to lock the sprung part,like a hand grenade type thing,then theres 2 12mm bolts and the whole thing comes out in one bit.
then you take it to the bench and remove the single bolt holding the tension roller and remove and replace,then simply bolt it back on making sure of belt route is correct and simply release the pin and tension will do itself after a few turns,the tension roller i got from ebay for less than a tenner,may have link i shall see,good luck
duke1
here is link,btw i do not think the tensioner ever wears out its just a big spring on a pivot so last pretty much forever,link
https://www.ebay.co.uk/itm/FOR-VOLVO-85 ... 2749.l2649
- Has thanked: 1848 times
- Been thanked: 1710 times
The springs do break and the bearing do seize. If you see the tensioner bobbing up and down when engine is idling it has failed. Replace it ASAP unless you want to toast the motor (serp belt jumps or snaps and takes out the timing belt cover and timing belt).
Some of the older tensioners have a Torx head (T45?) in the center of the tensioner. You need a shortie T45 socket.
loveMy850
Will somebody please tell me if the part nomber1275380 Volvo tensioner will fit my 1994 Volvo 850 wagon 2.4 5 cyl.
Duke gave me an excellent write on how to install the tensioner.
duke1
yes im sure it will fit yours is same year as mine and na so yes should be exact same,as scot said bearings and springs wear but tbh its real easy in a vice to judge this and mine had a visible wobble yet nothing wrong with spring or bearing at 153000 miles just tension roller was worn,replaced 1000 miles ago,zero wobble now,good luck
- 1247 Views
Last post by Faust
- 983 Views
Last post by mrscullini
