p80 nasty bad turds thread , renamed
Has thanked: 1506 times
Been thanked: 3820 times
Not sure if this is worthy, but had a nasty stuck strut bolt that snapped off during front end work, and also froze shaft in the knuckle. Was stuck for quite a longtime.
I ended up Dremel opening up the strut metal and popping off the strut with a pry bar
That Dremel work took 3 minutes
:D
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Scenarios line this make me wonder if an air hammer would be a good investment.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1002 times
Post by volvolugnut »
Keep those rust bucket stories coming. They make me appreciate that road salt is not used here.
volvougnut
Renamed thread to encourage people to post their bad carvrepair problems requiring “ innovative” approaches
Grinding, Dremel, oxyacetylene are all good indicators of thread worthiness
Lower control arm bolt fused to metal collar in rubber bushing
Had to be cut with 4.5 inch wheel.
Nasty!
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
I probably would have tried the angle grinder first on the strut. The Dremel would have been plan B.
turbo = angle grinder
NA = Dremel
"Carvrepair" has been permanently added to my lexicon.
Those reinforced Dremel wheels are great cutters. It was seconds to cut out around that stuck stud, not minutes.
The fused bolt on the lower control arm was awful In comparison
Has thanked: 1853 times
Been thanked: 1712 times
Well were would the fun be if all jobs went as planned?? :D
If all jobs were as planned you would not need the fancy tools like grinders and Dremels!! And if you even had the tools they would just stay shiny in their original packing.
As I seem to seldom had a job goes as planned, the worst case was the swapping the winter tires on to the V70R prior to a planned sale to fing the sub-frame cracked through! Long timers know how that worked out.............! :( :(
You are getting there each day and fewer knuckles left to remove the skin from.
Good luck with the rest!
Carvrepair tool list:
cheater pipes (various lengths)
BFH (various weights)
vise grips
pipe wrenches
abrasive grinders (various sizes)
gas wrenches (various temperature ranges)
magnetic parts pickup tool
finger parts grabber tool
adhesive tape (various strengths)
bandaids
emergency medical phone number/address
BlackBart
Been thanked: 885 times
Post by BlackBart »
^^ Good list.
On my son's LR3 Land Rover, we needed to change an air strut on one corner. Simple enough. Big bolts. Big everything on this car. We got the nut off, but the bolt itself was bonded / fused to the strut sleeve and no amount of pounding or PB blaster or heat would budge it. I pounded until it mushroomed.
We resorted to a sawzall with a badass Diablo blade. The head is recessed in the control arm stamping so you can't get behind it. We went in from beneath and cut the shock/strut sleeve collar and the bolt without cutting into the control arm. Went pretty fast after that decision - if you knew ahead of time there'd be trouble, you'd pull out the big guns and it would go pretty fast, but you always start with little wrenches and OE technique, and the job drags on!
That bolt shaft never did come loose.
Thin-sliced pepperoni - it was pretty accurate.
