adding extra back up lights
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Can I just tap into the trailer electrical connector, to hook up an Led light bar, for extra back up lights? I think I will mount it under the bumper..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
depends on how much current its drawing. to be on the safe side i recommend using a relay.
2001 XC70 factory M58
2002 XC70 auto (parts car)
azureblue
I'm not trying to re create the sun back there - just one of those small 6 LED units in the middle.
Would you know what the maximum current draw from the connector would be?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I don't think it would hurt. Just try wiring it directly to a bulb connector. I did so with the 3rd brake light, like the result, I think it helps getting more attention when braking www.youtube.com/watch?v=E_3Wrx2JvBE
azureblue
I was thinking about that too. So the extra drain on the bulb connector won't throw a warning?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- darrylrobert
I swapped all my rear lights with LED including the revereser lights, very bright and white not yellow. As for the bulb out warning, if i recall there isnt one for reverse lights, or i did the add a resistor to the shunt trick..
azureblue
Thanks - If there isn't a bulb out warning for the back up lights then A swap would work better
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
+1 on replacing the existing bulbs, did it on both my V70s, brighter and whiter both.
RichCrewe
- Year and Model: S60 2002
- Been thanked: 2 times
Could you tap into the trailer light circuit? (Ideally by just buying the correct cable/connector rather than splicing in.) If that's fused for a 21W incandescent bulb, that should support a fairly hefty LED array.
- 1962 Views
Last post by E Showell
- 1970 Views
Last post by volvobydefault
- 13 Replies
- 5996 Views
Last post by firstv70volvo
- 3605 Views
Last post by BEJinFbk
- 19 Replies
- 9517 Views
