It’s hard not to eye roll at the ‘plugged fuel filter’ diagnosis. Unlike Uncle Joe’s era, gas stations sell a lot cleaner product than the past, and we rarely see fuel systems getting gunked up.
This fuel filter came off a 1998 and ran 22 years and 180,000 miles, the fuel system was pristine inside , despite the filter being ‘ near end of life’
Bosch 71049
P80 How overbuilt are the Fuel filters 30671182 on our P80 ! Fuel filter autopsy
- Been thanked: 4063 times
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Interesting, thank you! I wouldn't have been gutsy enough to cut it apart with an angle grinder.
- Has thanked: 311 times
- Been thanked: 817 times
Why did you replace a perfectly good filter???!!!
Tape it up, Neil will buy it.
- Has thanked: 987 times
- Been thanked: 1075 times
I am reusing P2 filters on my 1977 Ford truck. Just back flush the crud and install inline with hose clamps. I figure it is big enough not to cause flow restriction.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Don't worry, he will put it to good use in his beetle along with the reused oil!erikv11 wrote: 28 Oct 2020, 13:47 Why did you replace a perfectly good filter???!!!
1996 855 R,
2010 V70 D5,
2010 V70 D5,
850oldschool
Abscate, did you let that thing bake in the sun for a while before slicing it open with the grinder?
It looks like you changed it just in time, before mass quantities of rust flakes started coming loose inside the shell.
It bake for about a month. I dislike gas bombs.
Look at how the top, which collects the fuel to be sent the injectors is pristine, while the rest of the filter is a dumpster fire.
Nasty people
- Clemens
It's just envy, because I'm never smart enough to use a kinda clead drain pan to catch the Volvos' oil so I could reuse it for the diesel T4... Maybe by the time I grow up I will get organized.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Neil, the gauntlet has been thrown.....volvolugnut wrote: 28 Oct 2020, 13:52 I am reusing P2 filters on my 1977 Ford truck. Just back flush the crud and install inline with hose clamps. I figure it is big enough not to cause flow restriction.
- 17 Replies
- 1804 Views
Last post by erikv11
- 1568 Views
Last post by precopster
- 13 Replies
- 4194 Views
Last post by BEJinFbk
- 23 Replies
- 10858 Views
- 26 Replies
- 3882 Views
