Extraction pump? Can I use it for Volvo?
From my days with my old Mercedes, I have a nice extraction pump. I used it for oil changes, etc. Can I EFFECTIVELY use a pump like this for my transmission? I did a drain and fill a few years ago, would like to do a series again, but would like to make it easier than crawling under and dealing with the driveway (I've grown tender in my older age). I could just 'suck' out the trans fluid and replace it. No?
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
I think there's a lot of ATF trapped in the torque converter and misc valves and you can't get at all of it. That's why only 3 quarts comes out the drain plug.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Sucking through the dipstick should work but you want the fluid to be a little warm so it flows better (no too much so you don't melt the plastic hose). Should be able to suck about 2-3qts this way. You can also replace the fluid at the return cooling line top of the radiator with green clip, few tips www.youtube.com/watch?v=Ad7HxgNP4s4
