Volvo #985186 bolt equivalent
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 36 times
Post by theWIFES_S70 »
On some of our favorite part supplier websites, this bolt is listed as discontinued. Not to worry!!!
Volvo 985186 is equivalent to an 8mm x 1.25 x 20mm bolt.
Head sizes are different. (OE is 12mm and the DIN aftermarket bolt is 13mm.) Flanges are exactly the same size though. Only other difference is the Volvo bolt has a washer built into it.
Retired:
2015 Volvo S60, T5, 85K
beigg
Year and Model: 850 97
Post by beigg »
both same tensile rating?
ugh smh 850 Turbo fridge
theWIFES_S70
Not sure. Can't read the markings on the OE Volvo bolt. But I would imagine 8.8 seems about right for this bolt.
The other bolt that holds up the rear muffler bracket read 8.8 on it.
This size does come in 10.9... https://www.boltdepot.com/Product-Detai ... duct=17744 but without the zinc-plated coating.
Retired:
Has thanked: 1505 times
Been thanked: 3818 times
That's an application where the bolt rating isn't too important
Im not sure this info is correct here
The intake manifold flange bolts are M7 , not M8
If you have a 12 ratchet or gun, m8s will go in , but........
Very light torque on these, like 15 ft lbs. barely a nip on the 6 inch ratchet
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
abscate wrote: 14 Nov 2020, 05:41 Im not sure this info is correct here
The M8 is for bolting some lower brackets to the intake manifold.
Has thanked: 1848 times
Been thanked: 1710 times
Many of Volvo's bolts are rated at 8.8 grade. Unless you are being crazy this grade is good.
