volvo etm vs electrical problem
spineda
Year and Model: 2001 volvo 70
Post by spineda »
first I would like to thank all who participate in this site your help is truly appreciated.
car is a 2001 Volvo v70 car has a crank no start issue I have been trying to trace this down and it appears that the etm does not click or whine on turning key to position 2 I checked fuse 7 ( etm fuse ) and it is intact. there is no voltage at the fuse per xemodex flowcharts, I replaced the main engine relay but still o success still no power to fuse 7 ( also there is no power to fuses 5-8) either.
my question is could this be a fuse block problem or does the ETM turn on power to the fuse block ie fuse 7.
I appreciate any help as I don't know where to turn next
thanks
steve
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
spineda wrote: 03 Dec 2020, 20:15 first I would like to thank all who participate in this site your help is truly appreciated.
thanks
steve
Based on the 2002 wiring diagram I have check fuse 11B/23, which supplies power to the main engine relay. Have you measured if there's voltage to the FMA2 main engine relay?
2_32 FMA2 relay.jpg (128.82 KiB) Viewed 2445 times
spineda
Post by spineda »
1 will check the fuse but which one is 11b/23 the fuses in the box are numbered. but there does appear to be power to one of the terminals pf the main relay I will look and check the other fuses in the block but if they seem just ot labeled numerically I believe thanks steve
spineda
Post by spineda »
in addition in the fuse block along the line that has fuse 7 there is power at the first three ports in the fuse block but no power at fuses 4 - 8
again I will chack and thank you
firstv70volvo
spineda wrote: 04 Dec 2020, 11:34 1 will check the fuse but which one is 11b/23 the fuses in the box are numbered. but there does appear to be power to one of the terminals pf the main relay I will look and check the other fuses in the block but if they seem just ot labeled numerically I believe thanks steve
See attachments, it's a 5A fuse.
spineda
Post by spineda »
thank you so much I will check the fuse tomorrow
the situation I have is that fuses 1 2 and 3 in the block have power but fuses 4 - 8 have no power with key on I did not know if the ECU needed to send
power to those fuses when key is turned on or is it a bad fuse block in either case I will check fuse 23 tomorrow again many thanks
ADent
Year and Model: 2001 V70 T5M
Been thanked: 5 times
Post by ADent »
Have you looked at the key switch at all? Mine went out and caused weird problems.
I did have a bad fuse block on an old 740 I bought, so it is possible.
On those under hood fuses it looks like 1 and 2 are tied together (with 10,12,13,16) and 3,4,5,6,7,8,11 are tied together. So it is strange 3 has power and 4-8 do not. 3-8,11 go thru FMA2.
2001 V70 T5M
1988 740 GLE 5.0
spineda
Post by spineda »
SEEMS TO BR SOLVED !!!
the problem seems to be the fuse 23
when I replaced the fuse the etm clicked there was power at fuse 7 and then the car started. I will put the car back together and test drive it but hopefully it is done!!
Thanks you to all
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
spineda wrote: 11 Dec 2020, 18:09 SEEMS TO BR SOLVED !!!
Thanks you to all
does the fuse you removed test bad ?
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Just an FYI, and I don't know if it matters for your specific issue, but the 2001 used a problematic MM throttle body and the 2002 (at least my old XC70 did) used a more reliable Bosch throttle body. I am not sure if the wiring is any different between the two, but it is something to consider when relying on wiring diagrams.
