Just a quick Sunday afternoon tip to report on a good tool combination that helped fix a small problem:
A 1/4" drive miniature breaker bar with a 7mm socket is slim enough to fit into the tiny space around the turbo outlet hose. It makes it easier (though not easy for me at any rate) to tighten up the hose clamps on the hose. My socket is a 6 point style, which is stronger than 12 point in some cases, but a 12 point socket would make it easier to get aligned onto the hose clamp.
Tightening the upper hose clamp:
And the lower hose clamp:
I learned that if you remove or replace this hose (Volvo part number 31261370, Turbo outlet hose) and don't tighten it up tightly, the car will run OK but eventually you may get an OBD2 code P0133 (Oxygen sensor bank 1 sensor 1 circuit slow response) and / or a P0422 (sometimes this one is Pending if not set) which is Main Catalyst Below Threshold (Bank 1).
If you get the above codes, make sure you don't have a leak in the intake somewhere. In my case, the leak was at this hose.
Quick Sunday Afternoon Tool Tip for tightening hose clamps on turbo outlet hose 31261370
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I had that pressure hose pop off at the intercooler side once. Barely made it to the next turnout before the car stalled.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
S60UT
- Year and Model: 2000 V70R
- Been thanked: 4 times
Mmmmmm, curious post and thanks for sharing the leak information. Im still getting error in Vida on the 00 V70R for fuel trim upper limit and sometimes catalyst. This may be something i have overlooked as possible cuprit. I did inspect the hose, but may not have tightened it down enough.
00 S70 GLT SE T5 Swap
00 V70R
99 V70 T5
01 E46 325XI Touring
09 FX35 Clown shoe
16 Jetta GLI
00 V70R
99 V70 T5
09 FX35 Clown shoe
16 Jetta GLI
- 38 Replies
- 13781 Views
Last post by 454cid
- 26 Replies
- 7025 Views
- 11 Replies
- 10010 Views
Last post by j-dawg
- 956 Views
Last post by smacknab
- 676 Views
Last post by Mike Langlois
