Hello, I'm trying to find out more about an issue I've been experiencing lately, along with some other people I know. Basically, if my car (2000 XC) is left out overnight at ambient temps of freezing or below, the ECC (climate control) will not power on for about around 5-10 minutes. No lights, no sounds, nothing. No stored codes in VIDA. Just dead. Doesn't matter if I restart the engine, jiggle or cycle ignition, reset battery cables, pull and reset fuses... nothing. The only thing that ends up working is waiting, and legitimately anywhere from 5-10 minutes later, it powers on and works totally fine.
I have a friend who has the same issue in his 98 T-5 and he knows of a few others that have experienced it as well. I believe he also swapped ECCs and had the same problem.
Any idea what this could be about? One of the few things that's stumping me. I've got a project 97 850 T-5 in the garage, so the XC has been freezing out at night and this issue happens every morning. Sadly, my commute is about 10 minutes, so it's been chilly.
Thanks!
98-2000 ECC Cold Temperature Issue, 9171800 intermittent
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Been thanked: 4064 times
Try bringing th unit in from the cold to see if you can isolate the problem to the ECZc control unit
Plug in before powering up, of course , standard good electronics practice.
I believe the 9171800 control unit is 1998 1999 2000 only?
Not hard to find, I might have one in my parts bin
thrich
- Year and Model: 2001 C70
Same issue with my 2001 C70. In cold weather the ECC is just completely dead, no lights and no communication with VIDA either. After a while it will usually start working. Didn't have this problem in the summer. I swapped an ECC from a 2000 C70 -- this one did not power up either. I checked all the ECC related fuses in the fuse box under the hood. I've got an extra ECC on the bench now to investigate. I don't have the 2001 item right now to confirm (car driven off out of town) but I recall the part numbers were the same for the two units from a quick look I did when both were out.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Now I think I'm going to pull my "semi functional" ECC out of my trunk and re-solder the connections for giggles. My guess is there is a power regulator on the B+ feed going to it and it gets cranky as it gets old. That or an electrolytic capacitor on the same stage failing... If I remember correctly, they hit some of this up with conformance coating... Not sure why as it should never get wet...
FlyingVolvo
I'm still trying to figure this out, but I've working on my 850 too much! Irritating for sure, and embarrassing for a car forged in the cold.
2023 V60 T8 PE
2023 V60 T8 PE
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
I like the take the LRU in the house overnight, that may determine whether the problem is in the box, or the circuit. Or pay a crew chief to bring you a heater!!
Current Volvos:
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Long shot, but there are also a few power contacts in the string.
Ignition switch and the accessory overload relay that it energizes.
Anything else inop while you wait for the ECC to wake up?
FlyingVolvo
Nope. Everything electronically is 100% good to go that I'm aware of. Just the ECC is straight up de-powered. Anything that I should check in particular?
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 2197 times
- Been thanked: 1850 times
If I recall, the A/C in the P80's does not work under about 10C. So if you have the A/C enabled it may have an over-ride in place until the cabin temp gets above that. Have you tried running the heating on manual rather than auto with the A/C dis-abled?
I think the whole unit Is electrically dead until it warms up, reading the top post.
11C/32 is the main fuse feed for the ECC CONTRIL UNIT, per the diagram
Pin C5 on the bus
Pin C5 on the bus
- 193 Views
Last post by jreed
- 31 Replies
- 8780 Views
Last post by sleddriver
- 2225 Views
Last post by PS78
- 51 Replies
- 22377 Views
- 1436 Views
Last post by JerseyT5
