12V source for testing Haldex pump 30783079 Topic is solved
- Has thanked: 292 times
- Been thanked: 765 times
When applying 12V to test if this pump is operational while in the car ... can I just use a car battery or I read somewhere to use a small 12v battery source?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 263 times
I just used a lead off the battery.
2003 XC 70 (sold)
Thanks for the quick reply. I was able to test it tonight.
It's dead, Jim.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1504 times
- Been thanked: 3817 times
Make up a fused test lead for this for a battery probe. Your battery will push a couple of hundred amps on a short and that can be quite spectacular
10-15 amp should work for most anything, you can even just use female spades to push into a standard Volvo fuse then wrap with electrical tape to insulate.
- Blacklab467
That's a better idea..........you always have to do things the right way, don't you abscate!
2003 XC 70 (sold)
Yeah I made up some test leads to easily hook to A spare battery I keep around and charged for jumps etc. Did not make an inline fuse I will add that in now for future tests. It was the amps I was worried about didn’t think about a short.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Always the right way the second time, the first time you short a battery to ground its memorableBlacklab467 wrote: ↑23 Dec 2020, 07:07 That's a better idea..........you always have to do things the right way, don't you abscate!
- Blacklab467
I've got a little experience with learning the hard way too, just replacing my front end for the second time this year........this time with good parts!
2003 XC 70 (sold)
- Has thanked: 927 times
- Been thanked: 1000 times
Expensive/difficult/painful lessons are the easiest to remember.
- Blacklab467
Did you find any life in your Haldex pump???
2003 XC 70 (sold)
- 2482 Views
Last post by 93SCMax
- 2040 Views
Last post by FattyArbuckle
