hi RickHaleParker ,
thanks for the useful tips
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
The Arduino code has a CAN-bus reset routine, which brings all devices back to live. You may want to add progModeOff(); as a last line in setup() function and remove everything from the loop() function.
vtl
You have no jumpers on J1, the end of bus is not terminated, lots of signal reflections.
https://www.allaboutcircuits.com/indust ... made-easy/
- efe09
- Year and Model: 2009 XC90 D5
- Has thanked: 17 times
Should I set a jumper on both CAN bus shields
put a jumper on J1?
Can you please help me out,
I do not have so much experience with it,
but I would like to complete this project successfully.
put a jumper on J1?
paddy0174
- Year and Model: MY2005 XC90
- Been thanked: 2 times
I can't be of any help "testing-wise", I still need to do some other things before I can even think about ordering the parts.
But if there are language barriers between english and german, I'm happy to help!
@efe09
Wenn Du Probleme bei der Übersetzung hast, kannst Du mir gerne Bescheid geben.
Gruss aus München
(translation: If you have problems with translations, just drop me a note! Greetings from Munich)
@efe09
Volvo XC90 D5 AWD Summum MY05
Harley-Davidson Ultra Classic Electra Glide MY91 FLHTCU
hi,
i was wondering if this board is a good candidate to use the code provided
https://copperhilltech.com/teensy-4-1-t ... 0-ips-lcd/
- 9888 Views
Last post by RickHaleParker
- 10223 Views
- 27 Replies
- 31450 Views
Last post by cn90
- 10 Replies
- 12034 Views
Last post by jonesg
- 6998 Views
