ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
MoVolvos wrote: 09 Jan 2021, 23:16
ndphotonl wrote: 07 Jan 2021, 06:37 Replaced the high beams with new LEDs. The old ones were from NightEye (right) and the new ones from Bullvision (left). They are a lot brighter and look like better quality.
ImageVolvo S80 2.4T H7 LED by Andy Ramdin, on Flickr
Have gone through over half a dozen LED's on two cars. Gave up on one as it just never last so gone back to Halogens for now. The best was the first set and it had the heatsink rather than the fan.
Understandable! I have this exact set on my S80 as low beams and it has been holding up well (since May 2019).
https://aliexpress.com/item/32921550280.html
It has the bigger heat sink attached to it. I needed to convert to led after converting the headlights to projectors. H1 halogen bulbs do not fit the projectors.
ImageVolvo S80 2.4T Retrofit Projector by ND-Photo.nl, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
I finally adjusted my right headlight so it's not pointing downward, and now I can hopefully see better at night if/when I'm out in the dark.
Both brights were aimed where they should, and I used that as my reference point. The left high and low both hit the same spot, so I figured the right should be the same way and adjusted it to match.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
ndphotonl wrote: 11 Jan 2021, 12:47
Thank you. Can you link to the Projector? My 03 S80 T6 is being parked for now so may have time to do some suspension and perhaps light work. Water is getting into both light assembly.
Just received the first Recall letter from Volvo for the Airbag stating there is a Recall but the parts aren't available. The Recall was Nov 7th or so. Only one person killed so they weren't in a hurry to notify customers.
MoVolvos
Post by MoVolvos »
liambean
Year and Model: 2001 V70
Been thanked: 3 times
Post by liambean »
Did a "smoke test" this AM trying to find where my EVAP leak is coming from. The smoke machine didn't make as much smoke as I hoped, but I did find it coming from here. Clearly, there is supposed to be a hose connected to this, but what hose? Whatever it is supposed to be, It's not there.
This is at the right rear of my 2001 V-70.
MoVolvos
Post by MoVolvos »
The 08 C30 T5 received it's first oil change using Castrol Edge Titanium 0W-40. Son reported 29 MPG on a 140 mile freeway trip. Previous oil change was with Liqui Moly 5W-40 and MoS2 Anti-Friction Engine Treatment. The best mileage was 27.8 MPG on the same 140 mile drive. All cars receive Premium fuel. Can't recall the last time using Regular grade fuel. Another first, car in garage after 5 1/2 years since relocating.
https://www.amazon.com/Castrol-03101-0W ... 903&sr=8-3
https://www.fcpeuro.com/products/5w-40- ... oly-lm3864
https://www.fcpeuro.com/products/mos2-a ... oly-lm2009
Angel Eyes / Halo & Silver Mirror Caps
Painted mirror caps silver similar to the R-Design caps. First attempt was more Chrome like but the Satin clearcoat ran like water so had to wait a day for it to dry and sand off. Primer after removing clearcoat and two thin coats of Rust-Oleum Metallic Finish. Paint still fresh so didn't buff with Griot.
https://www.lowes.com/pd/Rust-Oleum-Sto ... 1000737046
https://www.lowes.com/pd/Rust-Oleum-Sto ... 1000624793
Ceramic Coated car Tuesday. It's worth the cost, time, energy and effort. Sat for over 2 1/2 days in the garage to cure. Car has a sparkle shine, trim is black again, tail lights also has reflective sparkle and all exterior glass is slick. Didn't think to take pictures, son in hurry back to college.
Washed, clay, Mothers using DA with orange pad, Griot using DA with black pad, alcohol wipe entire car and applied Ceramic Coat and lightly buff. The clarity in the paint is not from buffing rather the coating itself.
Mothers removed scratches, Griot (Amazing) brought out mirror shine and Ceramic coating brought depth and sparkle to shine.
https://www.amazon.com/Mothers-05101-Ma ... 138&sr=8-3
https://www.amazon.com/Griots-Garage-10 ... 61&sr=8-11
Been thanked: 818 times
This week I finished the front end and a few other items on the new-to-us 07 XC70.
Replaced struts, spring seats, strut mounts, bump stops, front brake lines. Also three engine mounts (torque bottom, torque top, front engine mount under crank pulley). Fixed the leaking oil filter - it had an aftermarket cartridge that didn't seat properly and prevented the cover from threading down all the way. Changed the oil to Rotella 5w-40 T6 synthetic. Replaced the missing bolts on the splash cover, cleaned the splash cover and all oil leaks. Flushed the trans fluid with 12 quarts, first time since new it seems.
Have rear shocks waiting to go in too, maybe after this snowstorm's deposit melts and the roads are dry again I'll take it off the road to do that.
ndphotonl
Post by ndphotonl »
MoVolvos wrote: 14 Jan 2021, 02:01
Happy to help :)
Link to 2.5 inch projectors: https://aliexpress.com/item/32558103460.html
You can also buy 3 inch projectors, but I dont think they will fit. These ones clear the glass housing. If they were a smidge longer, than they would touch the glass.
These are the LEDs that I fitted (with the longer brass cooling fins) > https://aliexpress.com/item/32921550280.html . I dont have the caps on my headlights btw, have been driving around like that for quite some time without any issues (on multiple cars btw). If you fit LED in the low beams, then off course you need to do the shunt mod > http://www.xenonvalot.com/xenonfixvolvo.html
FlickR images
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Took the family for a nice drive in the country, wanted to check out the new front end on the highway and gravel roads and tweak the alignment a bit along the way.
2003 XC 70 (sold)
Has thanked: 1611 times
Been thanked: 4075 times
Those labs have the wrong colour code
