Locking issue 2001 v70 2.4 n /a
ashleyg82v702001
- Year and Model: 2001 v70
- Been thanked: 4 times
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
its not possible to repair the mechanism without destroying the casing. Get one from your junyard ,however if i leave the front passenger door open and try and lock the car, shouldnt all the locks pop back up?
EDIT: ok i just tried it and the front passenger door locks with the door open.The drivers door does not.
2001 XC70 factory M58
2002 XC70 auto (parts car)
ashleyg82v702001
All my locks pop straight back up with pass door open unless I flick the latch to closed with my finger then the car secures itself... Except the pass door.. Its gotta be the lock itself then I think.. Thankyou I'll pull the card and get the number
ashleyg82v702001
OK so moving on slightly I was looking at a trickle charge on the car (I have a separate post about ways to do it)
I bought a genius 5 charger / maintainer / repair unit
I fully charged, disconnected and ran the repair mode.
Battery seems to have a little more kick... I think but for the first run of the car all locks functioned perfectly.. 5 or 6 time consistently over a run lasting about an hour with various stops.
Got home and alas lock on passenger door has began buggering about again
I'm now wondering if my battery may be shot.
Could that be causing this issue? Not enough voltage
so it lifts one lock? If that's the case why does it deadlock.
Do these have a failsafe where a door unlocks if there is a voltage drop upon locking?
Anyone got an idea.
I don't want to spend £100 odd on a battery to find that's not the problem if I can help it
Anyone got an idea.
ashleyg82v702001
Well this is bizarre.... The problem has moved!
Still issues with the pass door but now the drivers front is occasionally immediately unlocking....
New battery on and a new alarm siren module fitted since last post. I've not yet found a door lock for the passenger front door.
- 17 Replies
- 4263 Views
Last post by Rattnalle
- 646 Views
Last post by phils94850
