Feel kind of stupid navigating their page, is it a SATURN valv body I'm looking for ?vtl wrote: 29 Jan 2021, 08:27 Best route is to replace the valve body with a new one, GM from ACDelco. It is even less expensive than Sonnax-rebuilt.
Yes, p/n 24228787 I think. In $500ish range. It requires a transfer of S2 solenoid and B5 spring.greffel wrote: 29 Jan 2021, 09:14 Feel kind of stupid navigating their page, is it a SATURN valv body I'm looking for ?
Attached are photos of the pressure gauge I purchased to do pressure checks. I've also attached my notes for the AC Delco valve body replacement. I'm not sure the valve body is a sure a fix for the 3-4 flare but it's possible. For the pressure gauge measurements I did have to purchase some 1/4 npt fittings to get to one of the taps; an elbow and extension. If you do change out the valve body read the notes for several things to pay close attention to.greffel wrote: 29 Jan 2021, 01:58 Hello again
Will have another go at fixing my 3-4 flare and now with delayed engagement P to D
With all your help and som local support the best bet is to replace the hole valve body, but it's kind of expensive for a car this old.
1. So one lead is that the S3 and/or S5 is leaking or is working slow (clogged)
2. The other one is that the line pressure is low and a shift kit from TransGo or Sonnax will help
If I would measure the line pressure at home what would I need to do and what PSI values are relevant ?
