Hi,
Has anyone had an issue where there is a delay from when the cruise control switch is pressed until when it is engaged and maintaining the set speed? I noticed that it drops about 10mph or so before coming back up to speed when initially set. Also, I think this only occurs at the beginning, thus I did not notice any issues when needing to reset due to braking etc. Please let me know if anyone knows what could be causing this and a possible fix.
Thank you.
1996 850R Cruise Control Delay Upon Activation
1337
- Year and Model: '18 VW Golf 1.8T 5MT
I'm curious about this too. Even after replacing the cruise control vacuum line, I still have this issue, exactly as you described it.
Current: 2018 VW Golf 1.8T Manual
Previous: 1998 V70 T5 Manual, Subaru BRZ, Mini, Miata, etc.
I have this issue too. I usually just hold the button for a second and then I feel it activate. No idea how to improve it.
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Same problem. It's been like this forever on both ma 850ies. I have a feeling this is the way it is due to its design.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Normal. The vacuum used by the CC has its own pump and it takes a little bit to get enough vacuum to pull the throttle.
Suggestion: when initially setting the speed, hold the button down until you feel the pedal drop from your right foot. It take 3-5 seconds.
Klaus
- Has thanked: 311 times
- Been thanked: 817 times
I agree, this sounds pretty normal. The cruise is slow to engage, you have to wait for it. It is possible there are some old failing pumps that are even slower than normal, you could try another pump from the junkyard, but for sure there is a lag anyway.
1337
This is what I do too. I think it's an endearing feature of the vacuum-based P80. It marks the transition out of my neighborhood and onto the highway in morning. "Houston, we have cruise control engaged. Roger that."Klausc wrote: Suggestion: when initially setting the speed, hold the button down until you feel the pedal drop from your right foot. It take 3-5 seconds.
- 506 Views
Last post by Ozark Lee
- 1594 Views
Last post by rspi
- 15062 Views
Last post by canicallyourose
- 17 Replies
- 6476 Views
Last post by ignatz
- 916 Views
Last post by alschnertz
