Well a Bazooka subwoofer fell in my lap, and I installed it in my trunk, taking power from the rear cig lighter for now. It sounds terrible though, very distorted. I'm hoping it's the laughably insufficient power for a sub.
Does anyone have any tips for a routing path of, say, 10 or 8 gauge wire from the battery? And think I should run a ground too or would you tap into the chassis in the trunk? If chassis, idea for where?
Running power to trunk for a subwoofer?
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I had a sub in my V70 once. Grounded on one of the bolts under the covers in the rear for the taillights. S70 should have similar covers. Power ran from the battery through the firewall hole, and underneath the inside trim between the door door sill and the carpet. They lift up and there's enough space there to stash a wire or two. Your cig lighter is definitely not going to cut it.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
wrybread
- Has thanked: 15 times
- Been thanked: 15 times
Thanks for that. Any tips on where to pass a wire through the firewall?
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
- RickHaleParker
- Been thanked: 977 times
If you want low lost power cables cheap. Go to a self service junkyard and get the long battery cables out of a P2 V70, S80 or XC90 which has the battery mounted in the trunk. They run between the floor and the carpet. $1.50 per foot around here. While you are at it get the plastic conduit for the cables and fab them for the best fit you can.
Active
Past
Past
- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
If you open the hood and look to the upper left corner of the engine bay, below the pressure lines of the AC, you'll see a rubber plug. You can pry that plug out and if you insert a powercable through the hole, it will appear in the passengersside below the dashboard (I think you guys call it the knee bolster?).wrybread wrote: 17 Feb 2021, 19:51 Thanks for that. Any tips on where to pass a wire through the firewall?
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
Links of rechts?Ocelot wrote: 20 Feb 2021, 09:50If you open the hood and look to the upper left corner of the engine bay, below the pressure lines of the AC, you'll see a rubber plug. You can pry that plug out and if you insert a powercable through the hole, it will appear in the passengersside below the dashboard (I think you guys call it the knee bolster?).wrybread wrote: 17 Feb 2021, 19:51 Thanks for that. Any tips on where to pass a wire through the firewall?
Bedankt.....
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
“You can pry that plug out and if you insert a powercable through the hole...”
Smokey the bear says:-
Please pass any cables THROUGH the rubber bungs or plugs, never run a cable through an unprotected hole in the fire wall or you’ll have just that - a wall ‘o fire . This also means a fuse at the battery not just a fuse at the amp.
Also be careful with some packaged ‘amp wiring kits’. They sometimes have an impressive looking big 30amp fuse but woefully under size cable buried under lots of red insulation to bulk the cables appearance.
The fuse at the battery is there to protect the cable.
The amp/sub should have its own fuse to protect itself.
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
- RickHaleParker
Don not pry the plug out. Cut an X in the center. Push the cable through. That way the rubber plug will keep the cable insulation from rubbing in the sheet metal, cutting the insulation and shorting out. Guy have burnt their vehicles to the ground by removing the plug instead of using the plug as an insulator.Ocelot wrote: 20 Feb 2021, 09:50 You can pry that plug out and if you insert a powercable through the hole, it will appear in the passengers side below the dashboard
After your done with the install. Dope the plug with RTV to make it watertight again.
Active
Past
Past
- Ocelot
Thanks SmokeyStu70 wrote: 20 Feb 2021, 12:02 “You can pry that plug out and if you insert a powercable through the hole...”
Recent car
Recent car
- 13 Replies
- 3205 Views
Last post by kallekula
- 1272 Views
Last post by precopster
- 3942 Views
Last post by bigsi15
- 757 Views
Last post by v-45magna
- 1592 Views
Last post by IronMike
