99' S70 weird coolant hose leak
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Hi guys,
Today my low coolant light came on. The car had a very slow leak already for a while so I thought I would just drive the car home after work and then top it up.
But there was a lot of coolant missing, way more than ever before. I traced it to this little rubber connector nipple right by the radiator hose:
Is this something that can be replaced, or am I in for a radiator replacement.
Thanks, Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 1846 times
Been thanked: 1710 times
I take it the nipple is cracked or damaged?
It may be possible to find a threaded nipple, remove the old one and drill and tap the top of the radiator and glue the fitting into there?
i take it the nipple is broken
Has thanked: 1503 times
Been thanked: 3817 times
I would dry it off and build a cone mountain of JB weld around that before buying a new radiator, too.
Drilling and tapping, and inserting a JB welded brass barb fitting is tier two
850 LPT
Post by 850 LPT »
It appears that there should be a plastic tube fitting that is molded in as part of the radiator. I found some images on the FCP website that show this pretty clearly. This probably broke off at some point during PO's ownership and they somehow cobbled up a solution with this rubber piece. I am surprised it lasted this long honestly.
I am looking into making a brass fitting that could be screwed or glued in. Not sure if threading that plastic is a good idea though, the plastic is probably thin in that area.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Before attempting glue or epoxy, clean well with alcohol.
Wall thickness of the radiator would make thread contact minimal.
850 LPT
Post by 850 LPT »
Wall thickness is my concern as well. And I am not really a fan of gluing things.
FCP sells new Nissens radiators for $110. I am tempted to go this route considering the fact that I don't know how old this radiator is and the car has close to 220k miles on it.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
I had this happen years ago. THere may be some creative solutions, but honestly the safest and most reliable long term bet will be to replace the radiator. I always try and be careful dealing with that nipple and the drain plug on the radiator.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I would've bought a new radiator.
BMW 540i 2002
S70 Base 2000
850 LPT
Post by 850 LPT »
Nissens radiator ordered. Not bad of a job. Plus, it's a lot faster on a stick shift car :D
Start spraying penetrating oil on the 2 radiator mounting bolts (one either end about half way down).
You could always keep the old one for experimenting on. I think the plastic is reasonably thick so drilling a hole for say a threaded barb and letting it self thread in and use a JB Weld type epoxy would give a good back up radiator.
Good luck!
