Anybody see this?
befarrer
Year and Model: 1998 V70 AWD
Been thanked: 24 times
Anybody see this?
Post by befarrer »
Just noticed my engine mount looks like this. Anybody else have this happen?
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
Has thanked: 1497 times
Been thanked: 3810 times
We get a much better top mount in 1999, unless you put poly in it.
That is a wear part and a pretty common failure on an aged P80
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I haven't seen mine do that. Usually the mounts crack and move too much forwards and backwards. The one in the image above looks like it popped out sideways, to the right.
I wonder if the front engine mount is OK, down by the passenger's front wheel. It might be worth checking that one to see if it has collapsed.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
98 S70 T5 & 03 S80 T6. Neither had a flared end nor flared bushings.
befarrer
Post by befarrer »
I'm wondering if I got a collapsed mount too. I have noticed the engine sounds just slightly louder when first started in the cab, only noticed if radio off, probably from this mount. Last time I opened the hood s few weeks ago to do an oil change, it was centered. Just got back from towing my quad on a trailer 300km round trip. I noticed it at my destination. No vibration or abnormal noises towing though, and I even have my AWD driveshaft installed.
98 V70 GLT AWD
05 VW Golf TDI
MoVolvos
Post by MoVolvos »
befarrer wrote: 11 Apr 2021, 16:51 I'm wondering if I got a collapsed mount too. I have noticed the engine sounds just slightly louder when first started in the cab, only noticed if radio off, probably from this mount. Last time I opened the hood s few weeks ago to do an oil change, it was centered. Just got back from towing my quad on a trailer 300km round trip. I noticed it at my destination. No vibration or abnormal noises towing though, and I even have my AWD driveshaft installed.
The first one I installed (URO from FCP) after purchasing the 98 S70 T5 only lasted around 1.5 years. They honored their Warranty as usual. Should probably do all 3 at one time just to be sure.
MoVolvos
Post by MoVolvos »
The attachment rod looks shifted to the driver's side also. It would be best to check or just replace all the other mounts if they are old and then center the new upper engine mount before tightening.
Shifted Mount.png (1.87 MiB) Viewed 1073 times
befarrer
Post by befarrer »
I checked my front mount, it looks ok. I am planning on changing all of my mounts in the near future. Engine looks level looking at it from the front. I can slightly shift the mount side to side on the engine bracket, so I think there was a bit of twist in the rear mount from tightening the bolt, and normal engine vibration caused the front bushing to vibrate out of the mount. I shifted it as best as I could to the center for now. I have an ipd poly Mount bushing for that somewhere, a guy was selling it who also had the 17" pegasus rims that I am running.
98 V70 GLT AWD
05 VW Golf TDI
MoVolvos
Post by MoVolvos »
The front mount has collapsed. The gap is suppose to be very small. The chugging or teeth chatter noise will get worse.
https://www.fcpeuro.com/products/volvo- ... 70-8631698
V70 Front Mount.png (2.08 MiB) Viewed 1038 times
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1240 times
Post by matthew1 »
Mm. It's not for certain that lower mount is toast. The lower bolt isn't biting into the casing... https://www.matthewsvolvosite.com/diagn ... ne-mounts/ like it is there. But that gap is a gap. Check the pin on the backside.
Also -> Amazon link
